Does a Boat Move When You Walk on It?
When a person walks on a boat resting in a placid river, the boat will indeed move in the opposite direction to maintain the center of mass of the boat-person system. This movement occurs because, for the center of mass to remain stationary, the boat must compensate for the person's movement towards the shore. If the person moves a certain distance towards the shore, the boat will move an equal distance in the opposite direction. The discussion emphasizes that this interaction is necessary to ensure that the center of mass does not change position, given the negligible friction between the boat and the river. Thus, the dynamics of the system require both the person and the boat to move in opposite directions to keep the center of mass stable.
alyafey22
MHB
If someone is on a boat that rests in a placid river with negligible friction between the boat and the river ,, suppose that person moves a certain distance ,Does that boat move as well , if so why ?
What do you think?
Doc Al said:
What do you think?
I think it will not move
So what happens to the center of mass of the boat+person system?
well ,, if the person moves for a certain distance , surely the center of mass will change in position ,but does that mean the boat has to move ?!
Can the center of mass of the system change? What is required for such a change?
yes it can ,, if we change the positions of the particles of that system with respect to a specified reference point .
What is required to change the center of mass of a system that is at rest?
an external force .
alyafey22 said:
an external force .
Right! Note that the problem states "negligible friction between the boat and the river". So what must be true about the center of mass of this system?
it will stay the same before and after the movement of the man .
Exactly. So, if the man moves a distance X closer to shore (say), how can you figure out how much the boat must move in order that the center of mass of the system stay put?
so the boat will move the same x-displacement as the man in order to maintain the same center of mass of the system .
Why would you think that? Are they the same mass?
there is a problem here because if the boat moves, the man as well will move .
Of course. So?
If the boat moves a certain distance to the left, how far must the man move? (Note that if you measure the man's movement with respect to the boat, then you have to add the movement of the boat to find his movement with respect to the shore.)
Doc Al said:
Of course. So?
you mean if the man moves towards the right , so he is getting closer to the shore, the boat will move in the opposite direction (to the left ).
Sure. How else can the center of mass remain the same distance to shore?
27K
12K
