Transformer Load: Do I Need to Worry?
  • Thread starter Thread starter rhlee
    Load Transformer
Using a transformer to step down 240V AC to 24V AC requires attention to the load it can handle. Transformers have internal resistance that limits the current they can supply without overheating, which is specified by the manufacturer. For example, a 2 amp transformer at 24 volts can safely support a load of 12 ohms. If the load resistance is too low, it risks overheating the transformer, so incorporating a fuse can provide protection. In power supply applications, it's crucial to minimize source resistance to maximize power transfer to the load, rather than matching load and source resistance.
rhlee
Hi physics forum,
I'm going to use a transformer to step down 240V AC mains to 24V AC.
I remember my physics teacher telling me about matching the load between the power supply and the load.
Do I have to worry about this in my case?
Regards,
Richard
No.
The transformer will have some internal resistance which will limit the current that can be supplied to any load you put on the transformer.
Manufacturers make this easy by telling you how much current the transformer can supply without overheating.
So, if it is a 2 amp transformer and supplies 24 volts, then the maximum load you can take from the transformer is 2 amps and this would be drawn by a load of 12 ohms.
This is Ohm's Law. Resistance = 24 volts / 2 amps = 12 ohms.
Any less resistance than this for more than a short time may result in the transformer overheating and possibly being destroyed. If you don't know what your load is going to be, you can include a fuse in series with the output to avoid overheating problems with the transformer.
Thansk for the info and safety advice.
When you're dealing with 'power supplies' you really want to avoid matching the load to the source. This would. of course, involve maximum power transfer but it will also involve producing twice as much power as you wanted and then wasting half of it!
Imagine - the series resistance of the 'mains' will be just a few Ohms. Put a load of this on the mains and you will produce a lot of smoke and sparks, drawing a huge amount of current and blowing the fuses. What you need, when supplying power, is as low source resistance as possible, so that as much of the generated power as possible is transferred to the load.
Matching is used in different circumstances - such as radio receivers and transmitting antennae.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
