C/C++ Converting string to integer using atoi in C++
The discussion revolves around a C++ programming challenge that involves reversing a string, converting it to an integer, and calculating its square root. The initial code presented has several issues, including improper handling of string lengths and incorrect output methods. The main problem identified is that the reversed string is not being stored correctly, leading to a conversion error when using `atoi`, resulting in a square root of zero.Key points include the need to initialize the length variable properly and to avoid using fixed-size character arrays, which can lead to truncation and buffer overflow issues. Instead, the use of `std::string` is recommended for better memory management and ease of use. The updated code successfully incorporates these suggestions, ensuring that the string is reversed and converted correctly before calculating the square root. The discussion emphasizes the importance of proper initialization and modern C++ practices for improved code quality.
zarentina
Hello, the problem that I was asked to complete was ; Write a program that inputs a string and reverses it. After the string has been reversed you must convert it to an integer and then take the square root of the integer. (using atoi)
My code is as follows:
Code:
int main ()
    int i=0,L=50, S,x,;
    double z;
    char ori_string[50];
    char new_string[50];
    cout<<"Please enter a long string"<<endl;
    cin.getline(ori_string,50);
    for(i=0;i<L; i++)
                 new_string[i]=ori_string[L-1-i];
    for(L=50-strlen(ori_string);L<50;L++)
                                         cout<<new_string[L];
cout<<endl;
     x=atoi(new_string);
     z=sqrt(x);
     cout<<"The square root of the reversed string is: "<<z<<endl;
    system("pause");
	return 0;
My problem is that my program isn't storing "new_string[L]" as anything so when I convert it to a integer nothing is there and the square root is zero. So my question to you all is how can i store "new_string[L]" so I can convert it to an integer using atoi?
Any advice would be delightful!
Thanks,
Z
Technology news on Phys.org
I don't know too much about C++ but atoi is string to int and atol is strong to long int.
Your code also seems to have a lot of stuff in it just to reverse a string and find its integer square root.
For example, why would you need anything to do 50 iterations?
First of all - you can't reverse the string assuming its length is 50 characters. What happens if it is not?
new_string[L] is a character (element of the new_string array), not a string. You don't have to write new_string to cout character by character, cout << new_string should work.
There is more, but I am not going to mention anything else now to not muddy the water.
When I first wrote this program to reverse my number I simply had
Code:
int main()
    int i,L,;
     for(i=0;i<L; i++)
            cout<<ori_string[L-1-i];
         system("pause");
	return 0;
This returned the proper number but it was preceded by random characters for the first 46 spaces if the string was 3 digits long. This was the reasoning of structuring a second for loop. Yet now that I know that is the incorrect method, how do you suggest I fix this bit of code here so that it will only output the reverse of the string for after it does that I can easily convert it to an int and take the square root.
(I know this differs from my initial question but I'm reasonably certain that this is where the problem is, yet if this assumption is wrong please let me know!)
Thanks,
Z
Hint: L is not initialized.
Hint2: with what should it be initialized?
*UPDATE* I had a revelation sparked by a few of your comments:smile:
Code:
int main()
    int i,L=50,x;
    double z;
    char ori_string[L];
    char new_string[L];
    L=strlen(ori_string);
     for(i=0;i<L; i++)
     x=atol(new_string);
     z=sqrt(x);
         system("pause");
	return 0;
Is my new properly working code, if there are any critiques or overhauls you may do feel free, I'd love to learn!
Thanks,
Z
Hi Z! Welcome to PF! :smile:
You're code will work properly.
If you want to learn I'll give you an improvement.
Your program won't function better, but it is better programming style.
In C++ we don't really want to use char-arrays anymore (it's a remnant from its predecessor C).
There are a number of pitfalls with them.
In this case the most obvious ones are that you have a maximum size (50) and that you truncate your input.
The C++ way to do things, is to use std::string.
It works like this:
Code:
#include <string>
int main()
    int i, L, x;
    double z;
    std::string ori_string;
    std::string new_string;
    cout << "Please enter a long string" << endl;
    getline(cin, ori_string);
    L = ori_string.length();
    new_string.resize(L);
    for (i = 0; i < L; i++)
        cout << ori_string[L - 1 - i];
        new_string[i] = ori_string[L - 1 - i];
    x = atol(new_string.c_str());
    z = sqrt(x);
    cout << "The square root of the reversed string is: " << z << endl;
    system("pause");
    return 0;
