Radio waves propagation & ionosphere
The ionosphere reflects short radio waves in the 25-30 MHz range due to the oscillation of electrons in response to electromagnetic waves. At low frequencies, electrons can oscillate in phase with incoming waves, allowing them to cancel and reflect these waves. In contrast, at higher frequencies, electrons cannot keep pace, enabling the waves to propagate through the plasma. The reflection occurs because oscillating electrons radiate new electromagnetic waves that interfere with the incoming waves, changing their direction. The plasma frequency, which determines whether waves are reflected or transmitted, varies with electron density and is influenced by factors like sunlight and atmospheric conditions.
ctapobep
I've read that ionosphere mirrors the short radio waves (25-30 MHz). So 2 questions:
  1. Why this happens? There is material on the internet, but it's rather complicated for me so far, I've just started to study physics. So I'd appreciate if someone explains this in more or less simple way.
  2. Why this is true only for a particular diapason: 25-30 MHz and why other waves go through the ionosphere without problems?
Science news on Phys.org
The ionosphere is a plasma. What we find with electromagnetic waves traveling through plasmas is that low frequency waves cannot propagate but high frequency can. The reason is that at low frequencies, the electrons can oscillate in phase with the waves which allows them to cancel out these waves. However, at high enough frequencies the electrons cannot oscillate fast enough to correllate with the waves due to their inertia. So what you see is that above a given frequency, electromagnetic waves can propagate in the plasma but below this frequency they cannot. Thus, waves incident on the plasma (ionosphere in this case) will reflect strongly if they are below the plasma frequency and will transmit into the plasma if they are above this frequency.
Okay, thanks for your answer. Have one further question:
And why the reflecting per se happens? What makes the wave reflecting? Now I understand that the reason is oscillation of electrons with the same frequency, but still don't get why this oscillation changes the direction of the wave..
Oscillating electrons radiate electromagnetic waves. That "new" radiation interferes with the incoming radiation. The effect of the interference (e.g. constructive or destructive) depends on the amplitude and phase of the "new" radiation with respect to the incoming radiation, which in turn depend on the frequency of the radiation and the properties of the plasma.
The same reason that you can see your reflection in a mirror. The oscillating charges are free to move enough when experiences a force due to the electric field in the impinging electromagnetic wave, that they "catch" the wave before it can travel any further, but then because they are still moving, they "throw back" the reflected wave. I realize these are imprecise terms, but you have to get into the math to understand the proper terms correctly.
Interestingly, the plasma frequency (the threshold frequency below which waves are reflected and above which waves are transmitted) in general is proportional to the average charge density of the plasma. That means that if there are more electrons, then higher frequencies get reflected. Depending on the time of day (more sunlight means more ionization of atmospheric molecules, creating more charged particles), certain frequencies will or will not be reflected by certain layers of the atmosphere.
Guys, thanks a lot for your help. I don't understand the full picture of course, but I understand much more than before :) If you know any good resources where I can find this information, I'd be grateful if you point me there (also interested in this maths that can explain the picture in more depths).
I find that most of literature in the internet is pretty hard to understand, seems like people write articles to look smart, not to share their knowledge.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
