Physical reason behind Plane Stress
The discussion centers on understanding the concept of plane stress and how stress values change with rotation. It highlights that stress is perceived differently depending on the angle of observation, which can be explained through Mohr's Circle. The varying stress values at different angles are not inherent material properties but rather a result of how forces are applied and analyzed. A practical example is given where steel under tension shears at a 45-degree angle, indicating that maximum shear occurs at this orientation. Overall, the conversation emphasizes the importance of visualizing stress through geometric representations like Mohr's Circle to grasp these concepts better.
FAlonso
I can now although do the maths related to plane stress etc but I have struggled to grasp the logic behind this concept. It says changing the way you see the stress by rotating the view, stress changes. My question is why ? Why is this so that we see stress with one value when standing at let's say 0 degrees with the axis of pipe under stress and different when we see it from 45 degrees rotated ? Is it some inherent material property or the force isn't really acting the way as we think and show in free body diagrams ? Can someone put it up simple ?
It's a function of mohrs circle. Plot the mohrs circle.you will see at different angles on the circle there is different stresses. In a real scenario if you put.steel in a tensile machine and pull it , it will shear at 45 degrees, this is because its maximum shear angle is 45 degrees
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
