Are You Using the Correct Formula to Convert Redshift to Megaparsecs?
  • Thread starter Thread starter Sagan369963
    Formula Redshift
The formula z x c = H x d is being used to convert redshift to megaparsecs, with H set at 71 km/s/Mpc and c as 299,792.46 km/s. While the calculations yield reasonable results for lower redshift values, higher values like z=10 produce excessively large distances, raising questions about the method's validity. The linear relation v=cz is not suitable for larger distances due to the universe's expansion dynamics. A more accurate approach is recommended, focusing on light travel time distance rather than comoving distance. For a comprehensive understanding, a referenced review article is suggested for further reading.
Sagan369963
z x c = H x d is the formula I am using to try to convert redshift to megaparsecs, where H I'm taking to be 71km/s/Mpc and c as 299,792.46 km/s. When I plug in .1 for z I get 1.377 Billion Light years (422.2429 Mpc), which sounds right. But when I plug in 10 for z I get the huge distance of 137.717 Billion Light years. Is that because of the comoving universe? I'm really just after the light travel time distance, not really where the galaxy is now. Am I using the wrong formula?
Space news on Phys.org
You are using linear relation v=cz, which is not good at larger distances. Try here, just plug redshift value and you will have light travel time distance.
To expand a little on Calimero's response:
The equation you are using is the linear approximation of the full expression for the expansion of the universe (given a particular cosmology). Here is an excellent review article which should answer your question in detail http://arxiv.org/abs/astro-ph/9905116
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Why was the Hubble constant assumed to be decreasing and slowing down (decelerating) the expansion rate of the Universe, while at the same time Dark Energy is presumably accelerating the expansion? And to thicken the plot. recent news from NASA indicates that the Hubble constant is now increasing. Can you clarify this enigma? Also., if the Hubble constant eventually decreases, why is there a lower limit to its value?
