How Do You Find the Inverse of a Function in Calculus?
  • Thread starter Thread starter sonya
    Calculus
To find the inverse of the function f(x) = (2e^x - 8)/(10e^x + 9), the correct approach involves rearranging the equation before applying the natural logarithm. By multiplying both sides by (10e^x + 9) and simplifying, the equation can be transformed into 10e^xy - 2e^x = - (8 + 9y). This leads to isolating e^x, resulting in e^x = (9y + 8)/(2 - 10y). Taking the natural logarithm of both sides yields x = ln[(9y + 8)/(2 - 10y)], thus the inverse function is f^(-1)(x) = ln[(9x + 8)/(2 - 10x)]. The discussion highlights the importance of careful algebraic manipulation in finding function inverses.
sonya
calculus help please!
if f(x)= (2e^x -8)/(10e^x + 9)
then wat is f^(-1)(x)?
i first took the ln of both sides...
getting lny = ln (2e^x - 8)/(10e^x + 9)
then using one of the properties i get
lny = ln (2e^x - 8) - ln (10e^x + 9)
and from here i get stuck...how do i solve for x?? am i doing it a totally wrong way?? please help!
Pretty much, yeah, you're doing it the wrong way.
Instead of starting right off with the ln (which doesn't really help, does it?) you might want to simplfy the problem a bit first.
Since y= (2ex- 8)/(10ex+9),
(10ex+ 9)y= 2ex- 8
10exy+ 9= 2ex-8
Now subtract 9 and 2ex from both sides of the equation:
10y ex- 2ex= -17 or
(10y- 2)ex= -17
Divide both sides by 10y- 2 to isolate the exponential:
ex= -17/(10y-2)= 17/(2- 10y)
FINALLY, take the ln of both sides:
x= ln(17/(2-10y)) so the inverse function is
f-1(x)= ln(17/(2-10x)) where defined.
(10ex+ 9)y= 2ex- 8
10exy+ 9= 2ex-8
er...wat happened to the y? shouldn't it b 9y when u expand the y thru the brackets??
ne1??
y= (2e^x - 8)/(10e^x + 9)
(10e^x+ 9)y= 2e^x- 8
10e^xy + 9y = 2e^x - 8
10e^xy-2e^x = - (8 + 9y)
Take ln on both sides
x = ln [(9y + 8)/(2 - 10y)]
so,
f-1(x) = ln[(9y + 8)/(2 - 10y)]
Yes, that should be 9y. HallsofIvy only made a careless mistake and the way I do this question is exactly the same as that of HallsofIvy.
Well, yeah, I did that to see if you were paying attention.
You BELIEVE that, don't you?
