Product of Two Terms: Determinant Evaluation and Vanishing Values in Terms of p
  • Thread starter Thread starter Nylex
    Determinants
The discussion focuses on evaluating a determinant and finding the values of x for which it vanishes, expressed in terms of p. The initial calculations lead to the equation x(x - p)² = 0, indicating that the solutions are x = 0 and x = p. Participants confirm the correctness of this result, with one expressing relief at realizing the mistake in their earlier approach. The conversation highlights the importance of correctly applying determinant properties to solve the problem. Ultimately, the correct values of x are established as 0 and p.
Nylex
Hi, I' not sure if I've done this question correctly so I just want someone to tell me where I've gone wrong (if I have).
Evaluate the following determinant as a product of two terms. Hence find, in terms of p the values of x for which it vanishes.
Grr, I can't seem to use LaTeX properly so I'll just "draw" the determinant:
x x 0
0 x p
-2x -p x
= x \left\vert \begin{array}{cc} x & p\\-p & x \end{array}\right\vert - x \left\vert \begin{array}{cc} 0 & p\\-2x & x \end{array}\right\vert
= x(x^2 + p^2) - x(2xp)
=x^3 + p^2.x - 2x^2.p
- x(x^2 - 2px + p^2) = 0
x = {-(-2p) +- [(-2p)^2 - 4.1.p^2]^1/2}/2
x = [2p +- (4p^2 - 4p^2)^1/2]/2
x = p
It doesn't look right to me :/.
x x 0
0 x p
-2x -p x
x = p
This is correct x(x-p)^2=0
==>x=0 or x=p
==>x=0 or x=p
LOL, can't believe I didn't see that :redface:. Thanks a lot :smile:.
