Question regarding gravitational potential
The discussion revolves around a question regarding gravitational potential calculations between two masses. The initial solution presented contains a typo, but the overall calculation is deemed correct. There is a request for clarification on the relationship between gravitational potential and distance, as the original inquiry lacks context. Additional explanation from the questioner is needed to facilitate a more accurate response. Clear communication will enhance understanding of the gravitational concepts being discussed.
Sanosuke Sagara
I have my solution and question in the attchment that followed.
there is a typo in your solution, your answer is right
After reviewing the attachment, I can see that you have correctly calculated the gravitational potential between two masses. However, your question about the relationship between gravitational potential and the distance between the masses is a bit unclear. Can you please provide more context or explain your thought process behind this question? This will help me provide a more accurate response.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
