Calculating heat generated by a resistance wire
To calculate the heat generated by a resistance wire, one must consider the wattage per square inch of the heating element and the efficiency of heat transfer to the target object. Key factors include the medium separating the coil and the object, which in this case is air, and the nature of the object being heated. The goal is to design an infrared heating panel that can heat epoxy to 350°F from a distance of 5 inches, with the coil potentially reaching 600°F to account for heat losses. The project involves using nickel-chromium wire, with specific length and resistance to be determined, ultimately aiming to save costs on commercial heating solutions. Understanding these principles will aid in effectively designing the heating panel.
privitmj
How can I calculate how much heat a resistance wire gives off when I energize it? For example, I have calculated the wattage per square inch of a heating element I plan on building. How do I know how much actual heat it will give off?
Thanks.
Think about it. Law of conservation of energy.
Or I should say how do I design an electric coil that when energize will heat an object 5" away up to 350F?
That's an entirely different question.
It depends. How efficiently the heat is transferred from the coil to the object? What medium separates them? Where else can the heat energy go? What is the nature of the object? etc...
The medium is air. I am basically trying to design my own infrared heating panel to heat an epoxy to 350F. I am not concerned about losses as I plan on over compensating with temperature i.e. designing a coil that will go to 600F or so. Basically i need to figure out how to calculate how much heat a coil has the ability to "give off". To go into more detail, I want to design a 16"x16" heating panel that has the ability to heat epoxy about 5" away to 350F. I plan on using a resistive heating wire and making my own coil. This should save me about $600 :OP
*I plan on using a nickel-chromium wire of lengh and resistance to be determined.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
