Length of string on instrument to produce specific frequency
The discussion revolves around calculating the position of a fret on a two-string instrument to achieve a specific frequency. The original calculations for the tension and length of the string were incorrect due to misinterpretation of mass per unit length. The correct approach involves using the full mass of the string rather than adjusting it for the new length. After recalculating, the correct distance from the upper end of the string to the fret is determined to be 1.9 cm. This highlights the importance of understanding the properties of the string material in frequency calculations.
idkididk
You are designing a two-string instrument with metal string 35.0 long, as shown in the figure . Both strings are under the same tension. String has a mass of 8.45 and produces the note middle C (frequency 262 ) in its fundamental mode.
To extend the range of your instrument, you include a fret located just under the strings, but not normally touching them. How far from the upper end should you put this fret so that when you press tightly against it, this string will produce C# (frequency 277 ) in its fundamental?
f= (1/(2L)) * (F/u)^.5, where f is the frequency, L is length of the string, u is the mass per unit distance, and F is the tension force.
So I found that the tension of the string to be 812N. Using that, I solved for x: 277= (1/(2x)) *(812/(.00845/x))^.5
x= .313, which means 31.3 cm. It's asking how far form the upper end, so 35-31.3cm = 3.7cm.
However, this is not correct. Anyone know why?
How did you solve for that? What units are the length and mass given in?
Edit: I see. Length in cm and mass in grams.
8.45 is the mass of the full string, so don't divide by the new (smaller) length to find μ. (μ is a constant for the string material, regardless of length.)
^I just tried that, 277= (1/(2x)) *(812/(.00845/.35))^.5, and got x=33cm, so the answer would be 2, but that's not it either
EDIT: Ok nevermind the answer is 1.9 lol. Thanks!
