How to eliminate mold in aqueous solution
  • Thread starter Thread starter tycon69
    Aqueous
A junior chemistry major encountered a problem with a dissolved racetam nootropic that became cloudy and developed mold after being stored in a poorly rinsed root beer bottle. The individual considered adjusting the pH with household items like lemon juice or ascorbic acid and filtering the solution through a coffee filter to salvage it. However, the primary advice from the discussion emphasized that the safest course of action is to discard the contaminated solution, as the exact nature of the contamination is unknown and attempting to salvage it could pose health risks. The thread was subsequently locked, indicating a consensus on prioritizing safety over salvage attempts.
tycon69
Ok, So I am a junior chemistry major doing organic research, but my question hasn't really occurred in organic lab and is really more microbiology related, but I assume chemists in certain fields have either run across this problem or already know how to prevent this from happening. I have a chemical, its a racetam nootropic (completely legal), that I ordered a gram of from a chemical provider. Because this nootropic is for personal use and not laboratory use, I have no access to lab chemicals, scales, etc. I dissolved the entire gram in solution and was going to measure my dose in concentrations of 2mg / ml H20. My problem is that because I was in a hurry, I poured this solution into a rootbeer bottle that I had only rinsed out twice with water. Well it appears that their was trace sugars in the solution and a few days later it turned from a clear solution to a cloudy solution with moldy fuzz floating around...
Now how am I to salvage this solution of nootropic? My first idea was to raise the pH a little bit (hopefully I still have a vial or two of 1 M HCl that I had stolen (yes i was so interested in chemistry that I stole a few chems and glassware from my terrible chem teacher) in high school). If I can't find that I was going to use a little lemon juice or whatever else I can find around the house (you think ascorbic acid would help? or is it too weak?). Then after a reasonable pH change, assuming a pH change would kill and prevent any more mold, I was going to filter it through a coffee filter a couple times (don't really have access to laboratory grade filters right now).
After doing this would the solution be safe to ingest? Or should I try to attempt some sort of other extraction method? That would be difficult as I can't just steal chemicals from the lab (im not in high school anymore). I'm sure no one would miss a few mLs of acetone, DCM, ethyl acetate, or any of the other common solvents I use everyday in lab, but I do not want to wait till after the weekend as I am trying to get a start on studying for finals.
Any suggestions or a confirmation of my idea would be great. Thanks alotH
Chemistry news on Phys.org
Safest thing to do is to just throw it away. You don't know what happened, you are just guessing.
I am locking the thread.
Likes hutchphd
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
