Transformers, its current and its resistance
A transformer connected to home AC has a measurable resistance, which allows current to flow. When a desktop power supply is connected, its power consumption varies based on load, such as gaming, which requires more energy. This increased demand on the power supply leads to higher energy consumption from the home AC, despite the transformer being the primary connection. The power supply's efficiency is influenced by the load on its secondary circuit, which affects the primary circuit through counter electromotive force (EMF). Understanding this relationship clarifies how power consumption can fluctuate even with a constant transformer resistance.
Taturana
Hello,
Suppose a simple transformer, not connected to a circuit (just to the home AC). If we get a multimeter and measure its resistance we will get a number. So if we plug it into the home AC, it will consume energy (constant power).
Now suppose we have a desktop computer power supply. Well, the desktop consumption varies: if we are playing a game, the video card is dissipating more power etc. So, I would imagine that if the desktop consumption raises, the desktop is not only consuming more from the power supply, but the power supply is also consuming more from the home AC, otherwise it will be a really huge non-optimized solution for power supplies. But I also know that the only thing connected to the home AC (if we look the power supply circuit itself) is the transformer, which is, in essence, an inductor (but acts like a resistor, it's a lot of cable, it has a resistance).
Given this, the main question is: if the unique thing connected to the home AC is the coil of the transformer, and this coil has a resistance, which let's a I current flows, how could the power supply consume less or more power from the home AC?
I think you all understand my question. Please, could someone give me a clear explanation on that?
Thank you very much
I can't do a detailed explanation as I don't know enough, but I believe that the different items that are consuming power in the secondary windings circuit cause various levels of resistance in the primary circuit through counter EMF.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
