Calculate Cut-Off Frequency for Low Pass Filter w/ 2 Op-Amps
  • Thread starter Thread starter ajbriggs
    Frequency
To calculate the cut-off frequency of a low pass filter with two op-amps, the standard formula fc = 1/(2∏(fn)RC) applies, but adjustments are needed for multiple stages. Each op-amp's individual frequency response must be considered, as they may have different values for fn, R, and C. The cut-off frequencies for each stage should be calculated separately and then combined to determine the overall filter response. The interaction between the two stages can affect the final cut-off frequency, so it's important to analyze the circuit diagram for accurate results. Properly calculating the cut-off frequency ensures optimal filter performance in the intended application.
ajbriggs
How do I work out the cut-off (corner) frequency of a Low Pass Filter?
I know the equation is fc = 1/(2∏(fn)RC)
but I have 2 op-amps in the filter both with different fn's, R's and C's
is it simply calculate each part separately and add the 2 values together?
Cheers
Show as the circuit diagram
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
