Finding Fan Curve w/ Orifice Plates & Fixed RPM
  • Thread starter Thread starter gomerpyle
    Curve Fan
To find a fan curve using orifice plates at a fixed RPM, the challenge lies in calculating flow due to the dependency of the coefficient of discharge on the Reynolds number, which is unknown without flow measurement. This creates a paradox where the flow cannot be determined without first knowing the Reynolds number. An alternative method suggested is to use the hydraulic diameter of the orifice at its exit to compute the Reynolds number. Additionally, it's noted that fan curves are typically provided by the manufacturer. Understanding these dynamics is crucial for accurately generating a fan curve.
gomerpyle
If I had a fan sitting in a small duct, and used several different sized orifice plates to create different restrictions, how would I find the fan curve? I run the fan at the same RPM each test.
The problem I run into is using the equation for orifice flow that relates pressure drop, area ratio, density, and coefficient of discharge to find flow. The coefficient of discharge is a function of the Reynold's number, but if the flow is what I'm trying to measure, then I don't know the Reynold's number. As a consequence of that I cannot know the coefficient of discharge, and thus cannot calculate flow for each orifice plate. Sort of like a paradox it seems to me.
Am I missing something here? Is there an alternative method to generating a fan curve?
Use the hydraulic diameter of the orifice at its exit to compute the reynolds number.
A fan curve goes with the fan, its manufacturer should have given it.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
