Trying to use LMS adaptive filtering to remove noise with a reference signal
The discussion focuses on the challenges of using LMS (Least Mean Square) adaptive filtering to remove noise from a noisy fNIRS signal, which includes a desired signal and a noise reference. The user is struggling with implementing an LMS filter found online, as it requires known desired signals for coefficient calculations, which they do not have. They express confusion about treating the noisy signal as the desired one and question the lack of literature addressing phase shifts in the filtering process. Additionally, the output signal becomes erratic towards the end of the file, but insufficient details are provided to diagnose the issue. Overall, the conversation highlights the complexities of adaptive filtering in the context of noisy signal processing.
softwareguy
I have a device (fNIRS, though knowledge of fNIRS probably isn't necessary to help) which produces very noisy signals and a noise reference. The noisy signal consists of a combination of a desired signal, and a noise signal, which is a scalar and phase shift of the noise reference. However, I'm pretty sure the scalar and phase shift change slightly over time.
Similar research all suggests adaptive filtering. Colleagues in another lab have been using an LMS (Least Mean Square adaptive filtering) subroutine, but its in a Matlab toolbox which we can't afford. I found an LMS filter online. After problems getting the filter to work properly, I looked at the literature, and I believe I understand how they work. However, I have some questions.
All of the explanations of LMS filters involve solving for the filter coefficients over time which will produce a desired signal from a noisy one, if you already know the desired signal. This appears to be useful to find unknown filter coefficients, but is not useful for my purposes. The filter I found appears to somewhat work if I treat the noisy signal as the desired signal, and the noise as the input, and then take out the output signal (which is theoretically modified to be as close to the desired/noisy signal as possible). This doesn't make any sense, and I feel like it must be wrong.
In addition, none of the literature seems to account for handling a phase shift. Am I missing something?
also, the output signal goes haywire towards the end of the file. I can't understand why this would be occurring.
Of course! What else. If you can't define the difference between noise and signal, then you can't design a filter. I'm sure you know that, so your question is ill formed.
As for going haywire at the end, you don't give enough info for us to guess.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
