Calculating Car Accident Speed: 100ft skid marks, 0.75g deceleration
To calculate the minimum speed of a car at the time of braking, given a 100-foot skid mark and a maximum deceleration of 0.75g, the relevant kinematic equation is vf² = v0² + 2as. By substituting the known values into the equation, the initial velocity (v0) can be determined. The calculations yield an initial speed of approximately 21.2 m/s, which can then be converted to mph. The discussion emphasizes understanding the appropriate kinematic equations rather than focusing on solving for time. The approach taken in the calculations is confirmed to be correct.
herbally
Investigating the scene of a car accident you measure the skid marks of one of the cars to be 100.0ft long. Assuming that the maximum deceleration on dry pavement is 0.75g, what was the minimum speed of the car(in mph) when it slammed on the brakes?
x=x0 + v0t +1/2at^2
v=v0 + at
I know I need to solve for t, but I can't seem to wrap my ahead around setting up the equations for these types of problems. A helpful nudge would be appreciated.
You don't need to solve for time, you are asked to solve initial velocity. You are given 3 values, displacement, acceleration, and final velocity.
I was under the impression that most of these problems begin with solving for time. I'm really in the dark on this stuff. My instructor leaves much to be desired.
Have you been taught all of the basic kinematic equations?
If so, look at each of them. You'll find that each one has a different variable missing.
Knowing this all you have to do is look for the equation with all the variables you're given and the variable you need and then use that.
This is what I did...let me know if I'm on the right track.
I used vf2 + v02 = 2as.
so v02 = 2(7.35m/s2)(30.48m)
v0 = 21.2m/s
I think that's right, but I'm not sure. Then of course I have to convert to mph. Am I close?
Yes, that is correct.
