Branched suction pipe foR a pump
  • Thread starter Thread starter prasan_y2k
    Pipe Pump Suction
The discussion revolves around a 0.25HP pump connected to three tanks via a branched suction pipe, resulting in a low discharge rate of 8-10 L/min instead of the expected 45 L/min. Suggestions include interconnecting the tanks to reduce friction losses, though concerns are raised about potential increased friction from smaller diameter pipes. The pump is identified as a 12 Volt DC Rotary Vane Pump, and the possibility of increasing the pump speed is limited due to its direct connection to a car battery. The consensus is that the discharge rate may improve with a single suction line and possibly larger diameter piping, though significant changes may not be expected. Overall, the discussion emphasizes the importance of pump speed and pipe diameter in achieving desired discharge rates.
prasan_y2k
A PUMP OF 0.25HP IS CONNECTED IN THE ABOVE FASHION (REF ATTACHMENT) TO THREE TANKS BY MEANS OF A SINGLE SUCTION PIPE. THE SINGLE SUCTION PIPE IS FURTHER BRANCHED TO THREE SUCTION PIPES, ONE EACH FOR THREE TANKS.
THE DESIGN DISCHARGE CAPACITY OF THE PUMP IS APPROXIMATELY 45 LIT/MIN. BUT PRACTICALLY, AS PER THE ABOVE ARRANGEMENT, THE DISCHARGE RATE IS SHOWN TO BE VERY LOW (APPROX 8-10 LIT/MIN). HOW CAN WE INCREASE THE DISCHARGE RATE OF THE PUMP??
IF WE INTERCONNECT THE TANKS FROM BOTTOM AND KEEP A SINGLE SUCTION PIPE AND REMOVE THE BRANCHING, WILL THERE BE AN INCRESE IN DISCHARGE RATE OF THE PUMP?
Given: Height of the pump from tank base: 1.5m
First, what type of pump is it? I'm assuming it's a centrifugal pump, and that's what the rest of this reply will be based on.
I don't believe that would help (connecting the tanks), especially since the reentrants would introduce more friction losses in your available suction head.
Can you increase the speed of the pump? It doesn't sound like you are having cavitation problems, or running the pump dry. Just sounds like you are getting low flow.
Do you hear any strange noises in the pump? Any vibration? Any pulsing in the discharge lines?
Generally we want to keep our suction lines large. When the three lines come together, do you increase the line size of the pump suction?
The pump is a 12 Volt DC Rotary Vane Pump. The pump is running on a 12 volt battery, so I cannot figure a way out to increase the speed. There is no strange sound or vibration in the pump. When the three lines come together, the pipe dia remains same (1").
I am still confused as how the interconnection of tanks will introduce more frictional losses in suction head. The interconnection of tanks (by means of 1/2" pipes) will make the suction line without branches, and make the 3 tanks behave as one.
Also, I would like to add that the discharge hose is 100 feet long and is kept on a hose reel. Nevertheless, even if the entire hose is taken off the hose reel, there is hardly any noticable change in discharge rate.
Yea, I don't see friction being your main concern here anyway. I don't think modifying that will change your system, it's a PD pump afterall.
I think speed here is your biggest concern. I would bet that your pump is not spinning fast enough.
Thanks for your reply.
The pump is wired directly from a 12V auxillary car battery and the battery is fully charged. Battery charges itself from the car's alternator. I don't see any way how to increase voltage, as that may lead to increasing speed.
But won't the pump make less effort in suction from one pipe(later after interconnecting the tanks) rather than three (as in the present case)?
It's a PD pump, suction isn't an issue, really. At a given speed, the pump will provide a certain capacity, basically no matter what. PD pumps are very good at suction head.
The only think I can think of is somehow the flow is being choked in the small diameter pipe when they all meet.
With that said, one suction pipe will probably make it more efficient, anyway. But not noticeably. If it isn't very expensive, go ahead and change the set up, and use a larger diameter pipe, reduce at the pump suction if you need 1 inch, just be sure to use the right type of reducer, or do it a few diameters upstream.
What type of drive is it from the motor to the pump? No room for a gear assembly or small sheaves?
What are the electrical requirements of the motor you are using for the pump? Do you have them available?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
