Solving Int. sin(9x)sin(16x)dx w/o Multiple Angles
The discussion focuses on finding an alternative method to solve the integral of sin(9x)sin(16x) without using the multiple angles formula. Participants suggest using the exponential form of sine and the identity sin(α)sin(β) = (cos(α - β) - cos(α + β))/2. One contributor claims that their method simplifies the process, allowing for an easier calculation of the integral. They assert that their approach leads directly to the answer, which is 1/14 sin(7x) - 1/50 sin(25x). The conversation emphasizes the desire for simpler techniques to avoid memorizing complex formulas.
ProBasket
\int sin(9x)sin(16x)dx
is there another way of solving the problem above besides using the multiple angles formula?
use this identity:
<br /> sin u = \frac{e^{iu}-e^{-iu}}{2i}<br />
edit:
expand the sine in term of exponential, multiply them and regroup them into 2 cosine, then do the integral
wow looks more difficult than using multiple angles formula. i just thought there's an easier way to do it so i won't have to remeber crazy amount of formulas when it's test day.
use
\sin{\alpha}\sin{\beta} = \frac{\cos(\alpha-\beta) - \cos(\alpha + \beta)}{2}
ehild
actually, my way is much much much more easier than remember you formulas...
I can eye ball the answer using my way...
the answer is...
1/14 sin7x - 1/50 sin25x
the expansion of the complex number is easy... there are only 4 terms
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
