Temperature range at which a reaction is spontaneous, Where is the mistake?
5 replies · 29K views · last reply
drtg45
For a chemical reaction we have, ΔH=-114.1kJ and ΔS=-146.4J/K ---> ΔS=-146.4·10[itex]^{-3}[/itex]kJ/K.
Question: Determine the temperature range at which the reaction is spontaneous.
A reaction is spontaneous when ΔG is negative in the equation ΔG=ΔH-TΔS, so I do:
ΔG=ΔH-TΔS
0>ΔH-TΔS
-ΔH>-TΔS
[itex]\frac{-ΔH}{-ΔS}[/itex]<T (the inequality sign changes direction when we multiply or divide both sides by a negative number right?)
[itex]\frac{ΔH}{ΔS}[/itex]<T (signs cancel each other)
[itex]\frac{-114.1kJ}{-146.4·10^-3kJ/K}[/itex]<T (we input the values)
780K<T , so this tells us that the T must be greater than 780K in order for the reaction to be spontaneous, but then when I check my answer in the original equation:
ΔG=ΔH-TΔS
ΔG=-114.1kJ-(900K)(-146.4·10[itex]^{-3}[/itex]kJ/K) ---> ΔG=18kJ , My inequality answer I suppose is wrong because if T is greater than 780K (in this example I used 900K) then ΔG is positive and the reaction is non spontaneous.
ΔG=-114.1kJ-(200K)(-146.4·10[itex]^{-3}[/itex]kJ/K) ---> ΔG=-85kJ , In here if we use a T lower than 780K the reaction is spontaneous.
I know I made a mistake somewhere because these results are not in accordance with each other, I'm guessing I made the mistake in the inequality while solving for T but I'm honestly not seeing it!, Where did I mess up?:confused:
Chemistry news on Phys.org
I prefer to stay away from negative signs when possible.
TΔS>ΔH
ΔS is a negative value, correct? So to quote you, "(the inequality sign changes direction when we multiply or divide both sides by a negative number right?)"
what does that do to your inequality when you divide the negative ΔS back over?
Hey thanks for your reply, I just finished posting something about inequalities in the General Math section, it would be great if you could check it out:
https://www.physicsforums.com/showthread.php?t=627753
maybe by doing what I describe in there the problems brought about by the minus sign and the change of direction of the inequality sign can be avoided?
-ΔH>-TΔS
plug values
(-1)(-114.1kJ)> (-1)T(-146.4·10^−3kJ/K)
multiply. do you have any negative values in your inequality?
ChiralWaltz said:
-ΔH>-TΔS
plug values
That's what I'm talking about, plugging the values before we get to make the mistake and change the direction in the inequality sign.
Since you have 2 negative numbers being multiplied on either side, they become positive. Now you don't have have negative numbers anymore, so you don't need to flip the inequality sign when you divide.
