Does volts and amps get at half while charging multiple batteries?
When charging two identical 50Ah batteries in parallel with a 100W 12V solar panel, each battery will receive the full voltage but only half of the current from the panel. The panel can deliver a maximum of 5.52A at its optimum operating voltage of 17.78V, while at 12V, it may provide slightly more current, around 5.8A. The open-circuit voltage of 21.5V does not allow for significant current draw. It is advisable to charge batteries separately to ensure better performance and longevity, as even identical batteries may not behave the same under load. Proper treatment of batteries is crucial due to their high cost and limited lifespan.
Panamanian
Hi guys (and gals)
Say, i have a solar panel rated at 100w 12v with the following specs:
Short circult current(Isc): 6.01A
Open circuit voltage(Voc): 21.5V
Optimum operating current: (Imp) 5.52A
Optimum operating voltage: (Vmp) 17.78v
Maximum power: (Pmax) 100W
And I decide to charge two 50ah batteries (each), from full discharged both, Does that mean that the voltage or amps will be split to half? (for each battery) or will both batteries receive the same (maximum) voltage and amp as if i was just charging one single battery with the same solar panel?
Also, if this panel is charging batteries or a battery, what's the maximum power it will be delivering (while providing energy) 17.78v? or 12v? or 21.5v? or what?
What for the amps too?
Gracias a lot.
If you have two batteries, identical in all respects, and you charge them as a parallel pair, then each will get half of the current from the solar panel. Each will get the full voltage. HOWEVER, as your batteries will never be identical, it is not a good idea to simply parallel them.
At 17.78v your panel, under the ideal conditions that the manufacturer tested it, can deliver 5.52A.
Power = V·I[/color]
At 12v expect to get fractionally more than 5.5A, maybe 5.8A.
At 21.5v you can't draw much current at all, that is the open-circuit voltage; draw any current and the voltage will fall away.
It is generally better to charge the batteries separately; the high cost & limited life of secondary batteries, compared with the cheap cost of electronics, means it is worth treating the batteries well.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
