Question about my computer - what is it compatible with?
  • Thread starter Thread starter bodeeeey
    Computer
The Acer Aspire Z3750 can be upgraded with a new graphics card and processor, but compatibility with the motherboard is crucial. The motherboard supports LGA 1156 socket processors, allowing for an Intel i5 upgrade. For graphics cards, any PCI Express x16 compatible card can be used, but a power supply upgrade from the existing 220W is necessary to support more powerful options. It's important to ensure the case has enough space for the new GPU and power supply, as prebuilt systems often have limited room. Low-profile graphics cards are recommended if space is a concern. Additionally, adding extra cooling fans is advisable, as factory models typically include minimal airflow solutions. For compatibility checks, resources like TigerDirect can help filter components based on specifications.
bodeeeey
hi there
I have an Acer ASPIRE Z3750, intel i3, 4gb ram, and I am looking into making it better, i was looking at geforce 570, 580, 590 etc and than i realized that my motherboard has to be compatible before i go and do anything, I've looked on thousands of websites and not one has helped me to figure out if it is compatible or not, and i really want to make my computer as good as it can possibly be, please help. I am also looking into putting a i5 processor in it but I am not sure if the computer will be compatible with it either.
Computer science news on Phys.org
This is the manual for your computer: http://support.acer.com/acerpanam/Manuals/acer/2011/ServiceGuides/SG_Aspire_Z3750_Z3751_Z5750_Z5751_20100910.pdf
Your motherboard's specifications are on the 10th page. To replace the processor, you need to make sure the new processor is compatible with the LGA 1156 socket (Socket H).
To replace the graphics card, you can get any PCI Express x16 compatible card. However, you will need a more powerful power supply than 220W to drive most good gaming cards together with the rest of your hardware, so you should upgrade this as well.
If you upgrade you'll have to make sure the case has enough room for a new gpu and power supply. Often these prebuilts are too narrow and that one is less than 4" deep. Be sure to also check how long a gpu it can fit.
I would recommend www.tigerdirect.com as they are very well organized and you can filter items based on compatibility. for example if you go to CPU, on the left you can select LGA 1156 and it will only show you processors that fit that socket.
if you are replacing the CPU and power supply, you might look at their Motherboard/CPU section, that way you can be sure to get a matching set of CPU and motherboard.
toss a few fans in there too, factory builds seldom give you any fans, sometimes if you are lucky they give you one. the more the better. place a few at the front bottom
The advice on the size of the graphics card is an excellent point. if you are concerned it may not fit then look at low profile graphics cards.
sucking in and a few on the back of the case blowing out.
Don
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
