What is the value of C2 when charged by a battery and connected to C1?
The discussion revolves around calculating the value of capacitor C2 after it is connected to a charged capacitor C1. Initially, C1 is charged to 155V and has a capacitance of 8.1 μF, resulting in a charge of 1.256 mC. When connected to the uncharged capacitor C2, both capacitors reach a final voltage of 20V, leading to the application of charge conservation principles. The final calculations yield C2 to be approximately 54.7 μF, confirming that charge is conserved in the system. The approach taken emphasizes the relationship between voltage, charge, and capacitance in parallel configurations.
PeachBanana
A 8.1 mu F capacitor is charged by a 155V battery (see the figure a) and then is disconnected from the battery. When this capacitor C_1 is then connected (see the figure b) to a second (initially uncharged) capacitor, C_2, the final voltage on each capacitor is 20V. What is the value of C_2?
Q = CV
(8.1*10^-6 F)(155 V) = 1.256 * 10^-3 C
1.256*10^-3 C / 20 V = 6.3*10^-5 F
I did it this way because I thought charge was conserved.
I believe you have correctly calculated the combined capacitance (eg C1 and C2 in parallel). That's not quite what the question asked.
I tried to find the potential energy stored in the capacitors but I don't think I did it correctly.
I used PE = 1/2 Q*V
Q = 1.256 * 10^-3 C
V = 135 V (unsure)
PE = 0.0847 J
From there I tried to find the value of C_2 since it said charge is conserved by using:
C = .5*Q^2/PE
C = 7.4*10^-3 F
If I remember correctly charge will be conserved (nowhere for it to go apart from being shared between the two capacitors).
So before C2 is connected..
Q = C1 * Vbefore
and after C2 is connected..
Q = (C1+C2) * Vafter
where
Vbefore = 155V
Vafter = 20V
equate
C1 * Vbefore = (C1+C2) * Vafter
Rearrange to give C2...
C1 * Vbefore = (C1 * Vafter) + (C2 * Vafter)
C2 * Vafter = C1 * Vbefore - (C1 * Vafter)
C2 = C1 (Vbefore - Vafter)/Vafter
Substitute values...
C2 = 8.1 * 10-6SUP] (155-20)/20
C2 = 54.7 * 10-6SUP] F
or 54.7 uF
Ok, the way you have done it makes much more sense. Thank you.
