Why are UNF threads being used in this high temperature Boiler Code application?
  • Thread starter Thread starter Pkruse
    Bolts
The discussion centers on the use of UNF threads in a high-temperature Boiler Code application, where nickel and chrome alloys are employed. The design engineer approved the use of threaded rods instead of hex bolts due to long lead times and higher costs associated with the latter. He noted that threaded rods are stronger as they eliminate the stress concentrator (KT) between the shank and head of a bolt. While the use of certified fasteners is emphasized for safety and performance, the engineer's choice was influenced by customer preference for UNF threads. Overall, the project utilizes certified materials similar to those found in jet engines, ensuring reliability in the application.
Pkruse
I saw the assembly of a high temperature Boiler Code application the other day. They used nickel and Chrome alloys for the high temperatures. I found the flanges to be particularly interesting. They were using UNF threads, which is not common in boilers, and they were using threaded rod with nuts on both ends.
So I talked with the design engineer. He had called out hex bolts on the drawing, but approved the change because they had a long lead time and were much more expensive. He also said that he likes the threaded rods better anyway because they are stronger, because they eliminate a KT between the shank and the head.
He used the UNF threads only because his customer was in love with them.
Have any of you ever considered this KT in one of your designs?
In critical applications where safety or performance are concerns, it's best practice to use certified fasteners (e.g. fastener lots that have had a statistical sample tested for strength). I could see how an engineer might be interested in the stress concentrator between the shank & head of a bolt if they're designing a bolt from scratch, but in the design of a large system (like a boiler) which uses off-the-shelf fasteners, I doubt you'd take this into account. More likely you'll find certified fasteners which are strong enough for your application.
Using a stud with threads on both ends doesn't strike me as particurally unusual, as long as you're able to find a stud with certified strength equal to that of the equivalent bolt.
I'm assuming that all material in this project is certified. They used the same nickel super alloys you see in a jet engine from the same suppliers.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
