Shape Operator for Schwarzschild spacetime in 2-dim
honeytrap
Hello:
I would like to understand how to compute the shape operator (and eigenvalues etc) for a complex example like the Schwarzschild spacetime. It's easy for a submanifold in Euclidean space, but I don't know how to do it for the more advanced examples like the schwarzschild spacetime in 2-dim.
QUESTION:
Given the Schwarzschild metric in Eddington-Finkelstein coordinates in 2-
dim:
ds^2 = -(1 - 2M/r)dv^2 + 2dvdr , which is a surface.
How can I compute the Schwarzschild
a) Shape operator (Weingarten map or second fundamental tensor)
b) unit normal vectorfield
c) Eigenvalues of the Shape operator matrix?
I know all the definitons etc., but the 2-dim Schwarzschild is not the typical
surface/ submanifold embedded in Euclidean space.
Could someone show me how to compute the steps a)-c) so that I understand it for this
example (and can apply it to other examples/metrics)?
Seriously, you want to describe the curvature of a 2-dimensional submanifold in a 4-dimensional one? In general that's going to be quite complicated -- a blend of the Gauss-Codazzi equations with the Serret-Frenet ones for a curve. Not simply a second fundamental form.
But anyway for the case you're describing, the (u,v) manifold in Schwarzschild spacetime, isn't the exterior curvature identically zero, by reflection symmetry? The normals to the surface would lie in the 2-sphere (θ, φ), and there would be no reason for the surface to be curved preferentially in any of those directions. I say, exteriorly speaking, it's flat.
Thanks for your answer!
I am actually interested in the 2-dimensional (u,v)- "Schwarzschild" manifold (surface) defined by the metric above.
From the shape operator (e.g. the eigenvalues = principal curvatures) you can derive the Gaussian curvature and the mean curvature. I computed the Ricci tensor and then the Gaussian curvature for the mentioned 2-dim manifold and both of them are not zero. Thus the eigenvalues (principal curvatures) of the shape operator matrix cannot be zero either. (Contradiction to flatness?)
I am interested in the eigenvalues and eigenvectors, but don't know how to compute them. I obviously need first the shape operator matrix.
Any help is appreciated!
If the shape operator includes the mean curvature, than there's no way you can compute it purely intrinsically! It depends upon the embedding.
Yes, having just looked up the definition of the shape operator, it certainly depends on the embedding. Intrinsically-defined surfaces don't have normal vectors at all.
This means then that it doesn't make sense to calculate the shape operator at all?
Or is there a canonical embedding that could be picked (e.g. 3-dim Euclidean/ Minkowski space)?
The computation would depend on the embedding and thus the result would not deliver any general information that could be useful for a discussion?
I assumed that since it was a subspace of Schwarzschild, you were embedding it in Schwarzschild! In which case my remark about the reflection symmetry applies.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
