F of G function question - Square root inside a square root?
The discussion centers around confusion regarding the notation of a mathematical expression involving square roots. The original poster mistakenly wrote √(√2 - x) instead of the correct notation √(√(2 - x)). Clarification was provided that using proper notation is crucial for understanding the problem. The suggestion was made to express the equation in exponent form to aid comprehension. Proper notation and expression are essential for solving the problem effectively.
nukeman
The image has the question I don't quite understand!
I understand how to get √(√2 - x) but I don't get how they end up with: 4√2 - x
Your notation is incorrect. This is what you wrote:
$$ \sqrt{\sqrt{2} - x}$$
What you should have written is
$$ \sqrt{\sqrt{2-x}}$$
Without using LaTeX, as I did, you could have written √(√(2 - x))
Do you see the difference?
Ah yea, I see the difference. Gotta start writing in latex!
I still don't understand the problem as I pointed out in the picture. ?
Write the expression in exponent form rather than radical form.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
