Finding the Kinetic Energy of Compton Scattering
The discussion revolves around solving a physics problem related to Compton scattering of X-ray photons. The initial calculations for the wavelength of scattered photons and the momentum of both incident and scattered photons were incorrect, with a corrected wavelength of 0.02722 nm provided. The momentum values were recalculated, yielding approximately 2.67e-23 for the incident photon and 2.43e-23 for the scattered photon. The kinetic energy of the scattered electrons was also recalculated, resulting in a negative value, which indicates an error in the calculations. The final momentum calculation for the scattered electrons was determined to be approximately 3.614e-23.
DODGEVIPER13
X-ray photons of wavelength 0.02480 nm are incident on a target and the compton-scattered photons are observed at 90 degrees.(a) What is the wavelength of the scattered photons?(b) What is the momentum of the incident photon and scattered photon? (c) What is the kinetic energy of the scattered electrons?(d) what is the momentum (direction and magnitude) of the scattered electrons?
1/E'-1/E = 1/mc^2(1-cos(theta))
E=pc
(lamda)'/hc-(lamda)/hc = 1/mc^2(1-cos(90)) (where mc^2 equals .511)
the (lamda)'=hc/.511(1-cos(90))+.02480 = .2426e-11 nm
then for b. E=pc so p=E/c=h/(.02480)=2.67e-23 and p'=E'/c=h/(lamda)'=6.626e-34/2.46200e-21=2.69e-13.
c then is E=pc=8.01e-15 = Rest Energy and E'=p'c=(2.69e-13)(3e8)=8.07e-5
then K=E-rest energy = 8.07e-5-8.01e-15=8.07e-5. Finally d is P=sqrt(2.69e-23^2+2.67e-23)=7.3212e-12
Is any of this correct if not where did i go wrong I think my methods are correct I am not sure about my units?
ok I screwed up the first part should be .02722nm. P'=E/c = h/(lamda)' = (4.136e-15)/(2.722e-11)=.000151947 and P=E/c=h/(lamda)=(4.136e-15)/(2.480e-11)=.000166774. For part (c) E'=p'c=(.000151947)(3e8)=45584.1 and E=pc=(.00016674)(3e8)=50032.2. K = E-rest energy = 50032.2-45584.1=4448.1. (d) p=sqrt(.000166774^2+.000151947^2)=.000225
Ok so once again I screwed up the first part should be .02722nm or 2.722e-11. then P'=E/c=h/(lamda)'=(6.626e-34)/(2.722e-11)=2.43423953e-23 and therefore p = E/c=h/(lamda)=(6.626e-34)/(2.480e-11)=2.671774194e-23. Which I then use to find the energies E'=p'c=7.302718589e-15 and E=pc=8.015322581e-15. Thus K=E'-(rest energy)= 7.302718589e-15-8.015322581e-15=-7.12603992e-16 which is IMPOSSIBLE coreect ugggg what did I do. p=sqrt(2.671774194e-23^2+2.43423953e-23^2)=3.614e-23
