Show that a mapping is continuous
  • Thread starter Thread starter DeadOriginal
    Continuous Mapping
DeadOriginal
Show that the mapping f carrying each point (x_{1},x_{2},...,x_{n+1}) of E^{n+1}-0 onto the point (\frac{x_{1}}{|x|^{2}},...,\frac{x_{n+1}}{|x|^{2}}) is continuous.
2. Continuity theorems I am given.
A transformation f:S->T is continuous provided that if p is a limit point of a subset X of S then f(p) is a limit point or a point of f(X).
Let f:S->T be a transformation of space S into space T. A necessary and sufficient condition that f be continuous is that if O is an open subset of T, then its inverse image f^{-1}(O) is open in S.
A necessary an sufficient condition that the transformation f:S->T be continuous is that if x is a point of S, and V is an open subset of T containing f(x) then there is an open set U in S containing x and such that f(U) lies in V.
I was thinking to prove this I would have to find an open set in the range of this function and show that its inverse image is also open in the domain but I am not sure how I would go about doing that.
Any help would be appreciated.
What is the definition of continuity you work with?
I have three. They are
Let f:S->T be a transformation of space S into space T. A necessary and sufficient condition that f be continuous is that if O is an open subset of T, then its inverse image f^(-1)(O) is open in S.
I updated the original post to reflect this.
I would use the first one. Given a sequence ## \mathbf{x}^{(n)} \rightarrow \mathbf{p} ##, prove that ## \frac {\mathbf{x}^{(n)}} {(x^{(n)})^2} \rightarrow \frac {\mathbf{p}} {p^2} ##.
I don't really understand. Can you elaborate a little bit? I don't know how I would show that a point x=(x_{1},x_{2},...,x_{n+1}) is a limit point.
You don't have to prove ## \mathbf{x}^{(n)} \rightarrow \mathbf{p} ##, this is an assumption. Given that assumption, prove ## \frac {\mathbf{x}^{(n)}} {(x^{(n)})^2} \rightarrow \frac {\mathbf{p}} {p^2} ##.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
