Speed of water and relation to light
50 replies · 10K views · last reply
Serge58
Fill a bowl with water, lay a piece of fabrics over the bowl, one end touching the water and the other end laying down on the table. Due to the capillarity effect the water will follow the fabrics and after a while it will be all wet. From this little experiment we can deduce that water travels, at a speed that depends of the type of fabrics, and has a maximum speed in each type of fabrics. We can even extrapolate that the speed of water in nylon can be something like 1 cm/minute. Silly isn't it? But its apparent speed is dictated by the medium that carries it.
That brings my questions related to light.
1. Could it be possible that light has an infinite speed but it is slowed down by the medium where it travels? Isn't there a vacuum permeability in the vacuum of space that would limit its speed?
2. (my favorite option) Is it possible that light doesn't move at all? Like the water in the previous analogy? That it just dissipates and follow the fabrics of space, even empty ones, as water in nylon? That would supply a different explanation of why light slow down in water and speed up when it get out.
Hi Serge, welcome to physicsforums!
The generally accepted model for light propagation in relativity is a wave model. However there are variations in the interpretations, as there are problems with details; in practice what people do is know how to calculate based on rules from wave mechanics. In that context it's easier to point out how your suggestions conflict or agree with currently used models:
- the speed of light in vacuum is a local constant determined by the vacuum and when light travels through water, it is effectively delayed due to interactions with the water molecules. See:
https://www.physicsforums.com/showthread.php?t=613481
https://www.physicsforums.com/showthread.php?p=3772953
- concepts as "vacuum" and "fabric of space" can be used with relativity theory.
However, this forum is not meant for discussing personal possible new theories (see Rules at top of the page). As you can see in the linked threads, refraction is very well explained by current scattering theory.
It has a fixed, constant speed in vacuum, for all observers. This is not possible if the vacuum would be some medium and light would travel relative to that medium.
It can travel from A to B, that is usually called "movement".
Water moves in your (wrong) analogy.
mfb said:
It has a fixed, constant speed in vacuum, for all observers. This is not possible if the vacuum would be some medium and light would travel relative to that medium.[..].
In fact, it has been known since 1904/1905 that this is possible and some of the early relativists related to such a wave model*. The problems with specific wave models do not depend on relativity. To mention a basic problem: As far as I know, a spherical transverse light wave emitted from a light source is an impossibility.
* see for example:
https://www.physicsforums.com/showthread.php?t=631954
https://www.physicsforums.com/showthread.php?t=590601
https://www.physicsforums.com/showthread.php?t=561128
(and many more)
Why is that a problem? That is just another way of saying there is no monopolar EM radiation. Why is it a problem that there is no monopolar EM radiation?
You can construct some co-moving ethers and whatever, but then you give up the concept of a preferred reference frame, and get the same predictions as SR (maybe just with a more complicated framework). Otherwise, you get predictions different from SR, which are inconsistent with experiments.
mfb said:
You can[..] give up the concept of a preferred reference frame, and get the same predictions as SR [..]
That's right; I simply corrected an erroneous claim. However, we were next both inaccurate. When I wrote that "the problems with specific wave models do not depend on relativity", I was only thinking of detailed mechanisms and not about what you call, "some co-moving ethers and whatever". While a Lorentz ether gives the same predictions, it is held that pluralistic "co-moving ethers" can't work as a model for SR (the prime argument was stellar aberration).
I think that you mean something else. I merely referred to an idealized classical spherical uniform light source that supposedly emits transverse spherical waves around it. Did you ever try to draw that in 3D perspective? I did and if I'm not mistaken, then that is a geometric impossibility. However, if I am mistaken, then I'll be delighted to find out how it can be done! :-p
I wish to reformulate my question. Why is there a maximum speed of light in vacuum? is it because it won't go faster or because it can't?
Light does not have a will, or "tries" to do something.
It has a specific speed (that is an observation), and you can derive this based on the Maxwell equations, for example.
The laws of physics are the same in all reference frames (another observation), this makes sure that the speed is the same for all frequencies and all directions.
According to Maxwell's theory on which SR was based, it's a property of vacuum, so that light can only propagate at the speed of light - similar to sound which propagates at the speed of sound.
See: http://en.wikipedia.org/wiki/Vacuum_permittivity
DaleSpam said:
It is impossible, I just don't know why that is a problem according to you.
Impossible means that such a basic classical model is plain wrong - simply due to self contradiction, without any need to introduce QM. I'm not aware of a more severe form of "problematic". :biggrin:
It is only a self contradiction if the model predicts it and it is impossible, but Maxwells equations do not predict a spherical transverse wave. The lowest order of radiation allowed by Maxwells equations is dipole.
Since it is not predicted the fact that it is impossible is not a problem.
So i can suppose that if light doesn't travel faster, it is not because it won't, but because it can't. It is possible to assume that light would go faster if it wasn't of the permittivity of vacuum?
Can you think of an experiment which could distinguish between "it won't" and "it can't"? If not, then the concept is philosophy, not science, and doesn't belong here. If so, then please describe the experiment and we can analyze what SR would predict.
DaleSpam said:
It is only a self contradiction if the model predicts it and it is impossible, but Maxwells equations do not predict a spherical transverse wave. The lowest order of radiation allowed by Maxwells equations is dipole. [..]
Good point! Assuming that that's correct, I'm afraid that this is not sufficiently recognized. A quick internet search produces on the one hand claims in courses such as
"light consists of [..] fields that travel through space as transverse waves", e.g.
http://ubpheno.physics.buffalo.edu/~dow/lectures/phy102/ch24_print.pdf ,
but also claims like "Spherical EM wave" and "The E.M. wave has a spherical wave front", e.g. both on slide 7 in http://www2.warwick.ac.uk/fac/sci/physics/current/teach/module_home/px384/lecture_05.pdf
and not to forget the typical SR computation based on "consider a pulse of light that [..] propagates as a spherical wave" such as in
and of course "let a spherical wave be emitted" in
http://www.fourmilab.ch/etexts/einstein/specrel/www/
Serge58 said:
[..] It is possible to assume that light would go faster if it wasn't of the permittivity of vacuum?
If vacuum permittivity and permeability are reduced, then also c is increased. In fact, as measured with a reference system on Earth, the speed of light is slightly reduced near the sun. That was predicted by GR and confirmed by experiments.
I found nice and clear explanations plus animations here:
- http://www.astro.ucla.edu/~wright/deflection-delay.html
But aren't they actually talking about aggregate collections of photons isotropically emitted from a symmetric source. Not a single wave in any real sense.
It looks to me that they are not talking about photons but about spherical waves just as they state; for sure Maxwell wasn't thinking of photons and neither was Einstein implying photons in his SR paper.
Harald - don't you think it's about time to grab a decent textbook or use any of the many good online resource, and actually learn the basics of EM theory? You argue a lot about validity of Maxwell's eqn's in relation to SR, without having any real understanding of ME's. To answer your conundrum about 'spherical radiation' which is actually dipolar or other multipole form: Spherical simply means that the constant-phase wavefront from say a dipole radiator is spherical at large r from such a source, not that the amplitude of that wave is spherically symmetric - an impossibility. It certainly is possible for a glowing sphere such as a star to output spherically symmetric radiation at large r from such a source. But the resolution is quite simple. Radiation from a star, or even a frosted light bulb, is the result of a huge number of chaotically phased and oriented individual radiators (colliding ions, atomic transition radiation). They do not cancel each other out owing to that random phase and orientation feature characteristic of thermal emitters.
Q-reeus said:
Harald - [..] You argue a lot about validity of Maxwell's eqn's in relation to SR [..]
Hi Q-reeus, I did not argue at all "about validity of Maxwell's eqn's in relation to SR" - quite the contrary, I mentioned that SR is based on it!
I mentioned in relation to the OP that we don't really understand what light exactly is but that for sure certain wave models can't be correct, such as spherical transverse waves which appear to be an impossibility. Next it was Dalespam who brought up Maxwell's equations by saying that those do not allow spherical transverse waves and I found that valuable input. :smile:
use any of the many good online resource [..]
Regretfully online university courses are supposed to be good online resources. Now, you seem to merely disagree with us about words and not about content:
Spherical simply means that the constant-phase wavefront from say a dipole radiator is spherical at large r from such a source, not that the amplitude of that wave is spherically symmetric - an impossibility.[..]
In my book a wavefront designates a constant phase, and I find two poles where this is impossible, so that the amplitude at those poles must be zero. Zero amplitude still implies no wavefront and no phase at those points. Are you really arguing about words? :rolleyes:
I mentioned in relation to the OP that we don't really understand what light exactly is but that for sure certain wave models can't be correct, such as spherical transverse waves which IMHO are an impossibility. Next it was Dalespam who brought up Maxwell's equations by saying that those do not allow spherical transverse waves and I found that valuable input. :smile:
Sorry, I should have been a little more specific. Didn't mean you were arguing with or against compatibility of ME's and SR. Rather that you were arguing for their compatibility, but then getting into issues - e.g. of impossibility of spherically symmetric radiation from a single oscillator as somehow a problem for classical EM/ME's.
Well it gets down to agreed definitions I suppose. It is simply an agreed and universally adopted convention that 'spherical wave-front' in respect of radiation refers to just that - the phase. Mathematically, although the amplitude drops to zero at the poles of a dipole oscillator far-field, we still have that the phase is defined. Otherwise we have some kind of axial 'singularity crisis' is implied. Anyway, keep happy I say. :wink:
I don't think that I mixed up Maxwell's equations with descriptions of wavefronts in some of the literature; however it was Dalespam who stressed their incompatibility.
That was exactly my point, which means that this is probably not about definitions. Thus I repeat:
Did you ever try to draw a [edit: transverse] spherical wavefront (thus with defined phase everywhere) in 3D perspective? I did and if I'm not mistaken, then that is a geometric impossibility. However, if I am mistaken, then I'll be delighted to find out how it can be done! :-p
Did you ever try to draw a spherical wavefront (thus with defined phase everywhere) in 3D perspective? I did and if I'm not mistaken, then that is a geometric impossibility. However, if I am mistaken, then I'll be delighted to find out how it can be done! :-p
Odds are you will have visited and studied the Wiki site here In which case you have noted that even when θ and thus the sin(θ) part goes to zero, phase is a well defined function of radius for a dipole oscillator far-field. It all reminds me of a website I came across where the individual there was hinging his/her entire case on that the field line of a bar-magnet that points exactly north or south 'never ends' - thus soundly 'refuting' the usually accepted position that lines of B always form closed loops. But I'm quietly confident you wouldn't subscribe to such an argument. :biggrin:
Q-reeus said:
Odds are you will have visited and studied the Wiki site here In which case you have noted that even when θ and thus the sin(θ) part goes to zero, phase is a well defined function of radius for a dipole oscillator far-field. [..]
A dipole oscillator far field is definitely not a transverse spherical wavefront. :wink:
But I will not continue this distraction from the OP's questions. [EDIT: OK then, one last time!]
Well it's always transverse in direction wrt a radius vector from source point (assumed a 'point source' at large r). And it's always a field having constant phase at a given r. So I'm sort of lost as to the point of actual dispute here Harald. Enlighten please. :confused:
A last remark on this: you apparently agreed that a spherical wavefront means a wavefront with the same phase everywhere on the spherical surface. Using the picture of that Wikipedia dipole article, you can see the transverse phase of the radiation going to the right; in particular the E-vector is indeed transverse to it and pointing "up" in the picture.
Now try to indicate the same for the radiation straight out of the top pole, thus the radiation that is going "up" in the picture and the electric field perpendicular to it. You will see that the transverse direction is indeed necessarily undefined; it has no transverse direction.
BTW you provided a useful link as it not only serves to explain it with a picture but it also links on to an article that explains this same point, although ignoring the phase aspect; there is no wavefront at the poles, it only lacks clear explanation why this is necessarily so:
http://en.wikipedia.org/wiki/Isotropic_radiator#Antenna_Theory
And with that, this little excursion away from the topic is for me closed. :smile:
harrylin said:
A last remark on this: you apparently agreed that a spherical wavefront means a wavefront with the same phase everywhere on the spherical surface. Using the picture of that Wikipedia dipole article, you can see the transverse phase of the radiation going to the right; in particular the E-vector is indeed transverse to it and pointing "up" in the picture. Now try to indicate the same for the radiation straight out of the top pole, thus the radiation that is going "up" in the picture and the electric field perpendicular to it.
Right - and the point is? Let me guess. Field strength, both absolute, and component along polar r direction in particular, goes to zero for θ = 0 (axial direction). Well that has been covered. We are talking about the very far field where only 1/r radiation component counts. At any point even infinitesimally displaced from the polar axis, there is a finite rms field strength, and the phase is as given there - strictly a uniform function of radius r only, entirely independent of θ. It's fine to say field has disappeared at strictly θ = 0, and in a sense phase has no meaning if E, B is zero there. But mathematically phase is always well defined, even in that limit as |E, B| goes to zero. And closer in, when near fields are appreciable, there is meaningful use of phase as fields are non-zero when θ = 0. In this near-field case, phase of net field, in any direction one may choose, is definitely not a spherical wavefront.
BTW you provided a useful link as it not only serves to explain it with a picture but it also links on to an article that explains this same point, although ignoring the phase aspect; there can't be a wavefront at the poles
Caught that just in time - glad it (hopefully) all adds up in the end. :smile:
Nice article but I don't get the relation with light being stuck at a certain speed due to permittivity and permeability.
