Finding Intersection of Tangents on a Circle
  • Thread starter Thread starter utkarshakash
    Intersection
The discussion centers on finding the intersection point of tangents to a circle defined by two points, z1 and z2, on the unit circle |z|=1. Participants clarify that while z3, the intersection point, does not lie on the circle, it is concyclic with z1, z2, and the center (0,0). The conversation emphasizes deriving the equations of the tangents and solving for their intersection, with one user expressing difficulty in representing the solution in terms of z1 and z2. After some calculations, a formula for z3 is proposed, but it is noted that the result may be incorrect, prompting a suggestion to check the signs in the derivation. The discussion highlights the complexity of translating geometric relationships into algebraic expressions in the context of complex numbers.
utkarshakash
Two points represented by z_{1}, z_{2} lie on circle |z|=1, the tangents to the circle at these points meet at the point represented by
Let the tangents meet at the point z_{3}. The centre of the given circle is (0,0).
∴ z_{1}, z_{2}, z_{3} and 0 are concyclic. Now what to do next?
It is not true. z1 and z2 are on the circle which centre is (0,0) z3 can not lie on the circle.
Find the equations of the tangent line and the point where they cross each other.
ehild
ehild
I'm not saying that z_{3} will lie on the circle with centre (0,0), Instead the 4 points which I mentioned will lie on some other circle and the centre of that circle will be the mid-point of line joining z_{3} and 0.
Sorry, I misunderstood you. You are right, z1,z2, (0,0)and z3 are on a circle. Find z3 in terms of z1 and z2. One possible way is to write up the equations of the tangent lines and find the intersection. Do you know the equation of a straight line in term of its normal? ehild
ehild
I know how to write equation of tangents in terms of x and y but not in the form of z. But I know the equation of a complex line.
A complex number has x and y components like a vector in a plane. Write up the equations of the tangents in terms of x1,y1 and x2,y2. The coordinates of the point of intersection are x3,y3. You can convert it to the complex number z3=x3+iy3.
ehild
ehild
But I have to give the answer in terms of z1 and z2 and converting the answer to the required form will be calculative. Any other methods or should I go with this?
Do it as you can and we will see.
ehild
ehild
After writing the equation in terms of x and y and then simultaneously solving the two lines I get
\LARGE z_{3}= \frac{y_{2}-y_{1}}{x_{1}y_{2}-x_{2}y_{1}} + i \frac{x_{1}-x_{2}}{x_{1}y_{2}-x_{2}y_{1}}
Now how do I represent this in terms of z1 and z2?
z=x+iy. x=Re(z) or (z+z*)/2; y=Im(z) or y=(z-z*)/2i. (* means complex conjugate)
ehild
ehild
After simplification I get
\LARGE z_{3}= \frac{2(z_{2}-z_{1}- \overline{z_{1}})}{\overline{z_{1}}z_{2}-z_{1} \overline{z_{2}}}
But this is not the correct answer.
Your result is not correct. Check the signs in your derivation.
ehild
