True/False Question on Linear Combos
  • Thread starter Thread starter NullSpace0
    Linear
If the system Ax=b has two known solutions, x1 and x2, it is true that another solution exists. Any linear combination of the two solutions, such as x1 + x2 or a weighted average, will also be a solution, provided the equation is homogeneous. Concerns were raised about whether this applies to nonhomogeneous equations, suggesting that different conditions may apply. The discussion also touched on concepts of uniqueness, rank, and free variables in relation to the solutions. Overall, the existence of additional solutions hinges on the nature of the equation and the properties of linear combinations.
NullSpace0
If the system Ax=b has two known solutions, x1 and x2, true or false that another solution exists. If it does, find another solution.
I think it's true. But after that, I don't know.
I'm really lost, but I think I remember learning that given two solutions, any linear combination of the two is also a solution. Does that mean that x1+x2 is a solution?
I'm worried that that is actually a solution to Ax=2b, though.
Perhaps that is only true for homogeneous equations, now that I think about it.
Would nonhomogeneous equations require some sort of weighted average linear combination?
Is it true that (1/2)Ax = A((1/2)x) ?
Is it given b is not the zero vector? Think about uniqueness, rank, and free variables.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
