How Electrodes in salt solution can increase the electric potential
Placing electrodes in the brain can elicit action potentials by manipulating the ionic balance within neurons. Neurons rely on sodium and potassium ions to generate electrical spikes, known as action potentials, through a process of depolarization. When electrodes are applied, they introduce an electric field that influences ion movement. Although electrodes supply a current of electrons, which are negatively charged, they create a potential difference that allows for the injection of current into the neuron. This process involves connecting the electrodes to a direct current (DC) source or battery, facilitating the flow of ions across the neuron's membrane. The key mechanism lies in how this electric field alters the ionic environment, enabling the neuron to reach the threshold for action potential generation.
Lucid Dreamer
Hello,
I'm not sure if this is the right place for this question, but I am trying to understand how placing electrodes in the brain elicits action potentials.
In a neuron (brain cell), there exists a solution of sodium and potassium ions (among other things). When the brain wants to produce an action potential (electrical spike), the neuron brings in a lot of sodium ions from the outside to make the neuron more positive. It is this positive depolarization that starts an action potential. To artificially simulate this process, we place electrodes on the neuron. My question is how is an electrode able to increase the potential? From what I understand, electrodes can only supply a current of electrons (negatively charged).
EDIT: A lot of papers refer to "injecting current in a cell." I don't understand what that means as you would need an acceptor of electorons within the cell (or a donor)
Chemistry news on Phys.org
Don't they connect battery to the electrodes?
Yeah, it's usually connected to a DC source or battery. But my questions has more to do with the actual mechanism of how electrons in the electrodes can be used to positively or negatively polarize a salt solution
Potential difference means there is an electric field present, doesn't matter what is its source.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
