Automotive Need Help Calculating MPH Increase From Reduction in Drag Coefficient
The discussion revolves around calculating the maximum speed of an electric motorcycle by adjusting the drag coefficient and gear ratio. The user seeks assistance in incorporating aerodynamic parameters into a spreadsheet to better predict speed changes based on drag reduction. It is noted that the power required to overcome drag significantly impacts speed, with specific calculations provided for a target drag coefficient of 0.37. Suggestions include modifying tire size, gear ratios, and focusing on aerodynamics to improve range and speed. The conversation highlights the balance between achieving higher speeds and maintaining torque for lower-speed performance.
Animag771
I am new to the forums and need help with something. I have been using a spreadsheet that somebody else made in order to help me design an electric motorcycle. I have been inputing my own data using most of his calculations and I have noticed that he did not calculate any aerodynamic parameters when into the formula for max speed. I have no idea how to do that, so I need the help of anybody who is willing. I have attached the spreadsheet.
Thanks,
Andrew
P.S. I am looking to get my drag coefficient down to 0.37 or lower, but I would like to be able to input the formula into the Max Speed cell (K28) so that when I change values in the spreadsheet it will update the calculations accordingly.
By my calculations the max speed is dictated by the maximum continuous speed of the motor, not the aero. The power required to overcome drag is given by 1/2*p*V^3*CdA. In your case of 56mph, that is just 2.6kW out of your 11.3kW motor.
Ok so the only way to increase the max speed would be to increase the tire size, change the gear ratio, or get a bigger motor. Thanks. I guess I will have to change the gear ratio and use the aerodynamics to increase the driving range, because my range will go down at higher speeds without aerodynamic modifications.
You can use this calculator to determine your maximum speed due to aerodynamics. Theory is at the bottom of the page to find how to calculate it.
For your motorcycle (CdA=0.25 m²; Roll. Rest.=0.02; weight=470 lb; wheel power=15 hp), it turns out to be 87 mph (with proper gearing, of course).
Thank you. I will just change the gear ratio a bit so that I will have a higher cruising speed and let the aerodynamics make up for the extra battery drain and reduce the drag at higher speeds. The only concern with changing the gearing though is how much torque will be needed to move the vehicle at lower speeds, because the aerodynamic benefits will be less help at lower speeds. Though that is an unrelated topic...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
