Vector Addition: A (41.0 m, 20.0°) + B (70.0 m, 44.0°) = C?
  • Thread starter Thread starter xobianca62ox
    Vector
Vector A has a magnitude of 41.0 m directed 20.0° below the positive x-axis, while vector B has a magnitude of 70.0 m directed 44.0° above the positive x-axis. The discussion focuses on using the component method of vector addition to determine the resultant vector C's magnitude and direction. Participants are encouraged to share their attempts and challenges in solving the problem. The original poster eventually resolved the question independently. The conversation highlights the importance of showing work for collaborative problem-solving.
xobianca62ox
A vector A has a magnitude of 41.0 m and points in a direction 20.0° below the positive x axis. A second vector, B, has a magnitude of 70.0 m and points in a direction 44.0° above the positive x axis.
(b) Using the component method of vector addition, find the magnitude and direction of the vector C(counterclockwise from the positive x-axis)
What have you tried?
Where are you stuck?
You ned to show us your attempt, before we can help.
nevermind i figured out the answer!
