Prove expansibility / isothermal compressibility
Expansibility (β) is defined as (1/V)(∂V/∂T) at constant temperature, while isothermal compressibility (κ) is defined as (-1/V)(∂V/∂P) at constant pressure. The discussion focuses on proving the relationship (∂P/∂T) at constant volume equals (β/κ). To derive this, the equation dV = (∂V/∂T)PdT + (∂V/∂P)TdP is used, setting dV to zero to isolate (∂P/∂T)V. This approach leads to the conclusion that the relationship between expansibility and compressibility can be established through thermodynamic principles.
Outrageous
β is expansibility , (1/V)(∂V/∂T) at constant temperature
κ is isothermal compressibility , (-1/V)(∂V/∂P) at constant pressure
How to prove (∂P/∂T) at constant V = (β/κ)
Thank you
Science news on Phys.org
Thank you
set dV = 0 to evaluate (∂P/∂T)V
Understand. Thank you
