Impact of Current loading for voltage multiplier
The discussion focuses on the effects of current loading in a 4-stage DC-DC converter charge pump circuit. The circuit produces an output voltage of approximately 4.6V from a 1V input, which is slightly below the expected 5V. Current loading impacts the output by causing ripple due to the output capacitor being charged briefly and discharging into the load, leading to a varying component on the DC output. To mitigate this ripple effect, using larger output capacitors is suggested. Understanding these dynamics is crucial for optimizing the performance of capacitor filter systems in similar applications.
shaikss
Hi,
Can you please let me the impact of current loading for the attached circuit?
The attached circuit is a 4-stage dc-dc converter- charge pump.
When I give an input voltage of 1V, the output voltage is around 4.6 V using cadence simulations. The expected output voltage is 5V.
I am able to understand and see the increase in the output voltage from stage to stage.
But I am unable to understand the impact the current loading.
I have attached the circuit and the plots which I got.
Can you please let me know the effects of current loading of the above circuit?
  • graphs.doc
    graphs.doc
This happens with most or all capacitor filter systems.
The output capacitor is only charged briefly by the rectified DC, and during the rest of the cycle, the capacitor discharges into the load. This causes "ripple" on the output. This is a DC output that has a varying component on top of it.
So, what you measure is the average value of the DC output, plus ripple.
Ths solution is to use larger capacitors.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
