How to build a speaker using an SMD audio (ring) oscillator?
To build a loudspeaker using a piezoelectric wafer, a fluctuating voltage in the audible range is required, which can be achieved with a small oscillator circuit. SMD ring oscillators operate at frequencies too high for audible sound, so alternative oscillators that can directly generate frequencies within 20 kHz are recommended. Some buzzers come with built-in oscillators tuned to the appropriate frequency, which can simplify the design. A suggested circuit using NPN and PNP transistors can produce narrow pulses suitable for driving a piezo transducer, with frequency adjustments possible through resistor and capacitor changes. Overall, finding a suitable oscillator or using a buzzer with integrated circuitry is crucial for achieving the desired sound output.
Rhydo
Hi!
I aim to use a piezoelectric wafer and get it to work as a loudspeaker by supplying it with a fluctuating voltage withing the audible region. I know this can be done using a simple DC to AC invertor/oscillator circuit, but the challenge is to build it as small as possible.
I looked up the working of SMD Ring-oscillators but their operating frequencies are way above the Megahertz range, so from what electronics I' am learning I don't think I can couple one of those with a piezo-wafer since the audible range of hearing for humans is 2 hertz-20 kilohertz.
Can anybody help me with this problem? Where am I going wrong? Can I actually use a megahertz range ring-oscillator running off 3.3Volts to get a piezoelectric buzzer to produce sound?
Are there SMD audio-oscillator chips available that can be directly coupled to a voltage source and be used to get a piezoelectric wafer to generate audible sound?
I have tried my best to find a solution, but I cannot see where I' am goin wrong since I cannot find any proper "SMD audio-oscillator chips" that give an output within 20kilohertz range!
ANY suggestions will be appreciated! I really need help!
Thanks in advance!
First, is your piezoelectric wafer broadband? Because piezo materials give force but little displacement, matching them with air is difficult, but this eases a lot if they can be resonated and the matching acoustic components as well, so this is done in buzzers, which are narrow-band.
A ring oscillator won't go down to the audible range, but other oscillators can be very small and works directly at the proper frequency. You don't even need a divider.
Some buzzers include an oscillator, already tuned to the proper frequency.
You could try a circuit i have used a lot.
It is like this:
http://dl.dropbox.com/u/4222062/NPN%20PNP%20OSC.PNG
As you can see, it uses a PNP and a NPN transistor and produces narrow pulses into a speaker or an 8 ohm load.
The sound isn't very musical, but it can be very loud.
To drive a piezo transducer, which I assume is open circuit to DC, you would use an 8 ohm resistor as shown and connect the piezo device across it.
The above simulation gives an output period of about 7 mS, so the frequency is about 140 Hz. If it works as shown, the 100K resistor should be left alone and the capacitor changed to adjust the frequency.
Changing the resistor too much may cause the oscillation to stop.
You could make the resistor partly variable (by putting a pot and a resistor in series) and adjust the pot slightly to get suitable output. Be careful, though, because you can blow up transistors by reducing the base resistor too much.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
