Create a DB15 Circuit Schematic | Schematic Generator
To create a DB15 circuit schematic, software options like Eagle and KiCAD are recommended, as they allow for easy customization and PDF export. Users can also utilize Visio for simpler diagrams. For testing circuits, breadboard simulator software like Tinkercad can be beneficial. PDFCreator is suggested for those needing a PDF document printer if the software doesn’t have a direct export option. Utilizing these tools ensures a neat and functional schematic for the custom circuit.
Zyzoggman
I have to make a terminal block from a DB15 connection. I'd like to have a neat looking schematic for it. I don't need to design a PCB, but just make a schematic for a custom circuit. Does anybody know of any software that you can build a schematic and then save it as a PDF or something?
Welcome to the PF.
I did a quick search of the EE forum for threads with the word schematic in the title, and found this thread:
https://www.physicsforums.com/showthread.php?t=56404
In addition, if you already have Visio, you can use that to do fairly simple schematic diagrams.
Thanks a lot. Guess I didn't realize where the search function was earlier. >.<
I don't mean to brow-beat, but there's an active thread (about 10 threads down at this particular moment) entitled "Does anyone know a program for creating schematics?" where you'll find a more current survey of free (or freeish) schematic-capture programs:
https://www.physicsforums.com/showthread.php?t=661488
Both of my recommendations, Eagle and KiCAD PCB allow you to "plot" the schematic diagram (to postscript or PDF, if I recall correctly). If not, I highly recommend PDFCreator to install as a PDF document printer (but use the plot option where available, rather than just printing the schematic page):
http://www.pdfforge.org/
I would recommend using a schematic generator software such as Eagle or KiCad to create a DB15 circuit schematic. These tools allow you to easily create and customize schematics for your custom circuit, and then export them as a PDF for a neat and organized layout. Additionally, you can also use a breadboard simulator software such as Tinkercad to test your circuit before implementing it. This will ensure that your schematic is accurate and functional before physically building it.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
