X-ray question - frequencies and energies
Higher frequency X-rays possess greater ionizing and penetrating power due to their increased energy, which allows them to interact more vigorously with matter. Gamma rays, despite having higher frequencies, have lower ionizing power primarily because they are neutral and lack mass, meaning their interaction with charged particles is minimal. The penetrating power of radiation is inversely related to the probability of interaction, which decreases with higher energy levels. For alpha and beta radiation, increasing their speed can enhance their ionizing power, but the relationship is complex and influenced by other factors. Overall, the discussions emphasize the roles of energy, charge, and mass in determining the properties of different types of radiation.
Deathnote777
X-ray question -- frequencies and energies
1. Why does x-ray with higher frequency possesses higher ionizing power and penetrating power ?
2. Will gamma ray with higher frequency possesses higher ionizing power and penetrating power ? And is "gamma ray has no mass" a reason accounting for its low ionizing power ?
3. Then for alpha and beta radiation, will they possesses higher ionizing power and penetrating power by increasing their speed ? Thank you.
Nil
1. Is it because energy of it increase ? So it can hit air molecules more vigorously and possesses higher KE and travel longer ?
2. I think mass should be one of the reasons just like that of alpha radiation. But my book says it is not. Only charge affect gamma 's ionizing power
3. I think yes ?
The first part is right, but the increased penetrating power is a different effect - the probability of an interaction goes down with increasing energy. This is a result of quantum mechanics, I don't know of any classical model to explain it.
I don't think this is a meaningful question. If a photon would have mass (in particular, enough to see it in gamma ray absorption), we would live in a completely different world.
Charge in the absorber - the gamma rays (photons) have no charge.
3. I think yes ?
Right
Thank you
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
