Why does fructose reduce Fehling's solution?
  • Thread starter Thread starter Hysteria X
The discussion focuses on the use of Tollen's and Fehling's solutions as confirmatory tests in organic analysis, particularly regarding fructose. It highlights that fructose in aqueous solution exists in a dynamic equilibrium with its other forms, which contribute to the reduction reactions observed in these tests. The conversation suggests that the presence of certain functional groups in fructose is responsible for its reactivity with Tollen's and Fehling's reagents, emphasizing the importance of understanding these chemical behaviors in organic chemistry.
Hysteria X
is it because of the keto group it has? what generally reduces fehlings solution and tollens reagent??
Chemistry news on Phys.org
You must know which group in organic analysis uses Tollen's and Fehling's solution as confirmatory test.
Actually, fructose in aqueous solution is not just fructose. It changes its form, being under kinetic equilibrium with its other forms (try to guess), which in turn are responsible for those confirmatory tests.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
