Early Diff EQ Solving Methods (Chp 1 status yo)
  • Thread starter Thread starter Kevin2341
    Diff eq
This discussion focuses on the methods for solving ordinary differential equations (ODEs) in a Differential Equations (DE) class. The three primary methods discussed are Separation of Variables, the "Guessing" method (y = yh + yp), and Integrating Factors. The conversation emphasizes the importance of recognizing the characteristics of the ODE, such as linearity and order, to determine the appropriate method. A systematic approach is suggested, starting with identifying whether the equation is first or second order and checking for constant coefficients.
  • Understanding of Ordinary Differential Equations (ODEs)
  • Familiarity with the Separation of Variables method
  • Knowledge of Integrating Factors
  • Basic concepts of linearity in differential equations
  • Study the characteristics of first and second order ODEs
  • Learn the application of the characteristic equation for constant coefficient equations
  • Explore the method of undetermined coefficients for non-homogeneous equations
  • Investigate Bernoulli equations and their specific solving techniques
Students in Differential Equations courses, educators teaching ODE methods, and anyone looking to deepen their understanding of solving ordinary differential equations.
Kevin2341
Alright, got a quick differential equation question.
So far in my DE class, we have learned 3 methods of solving ODE's
-Separation of Variables
-"Guessing" (the y=yh+yp method)
-Integrating Factors
How do you know when to use these methods and when not to? I understand the methods to use each of these three (Although guessing is still pretty sketchy when it comes to actually guessing).
Does it have something to do with linearity? Or is it simply just which ever method is "nicer"? I know with integrating factors sometimes you end up with integrals that are impossible to solve, so in that case, you'd need to resort to guessing.
I would look at the problem and ask myself, in this order:
1. Is if first order? If so then
2. Is it constant coefficient? If so use the characteristic equation and ##y_h,\, y_p## if it is non-homogeneous.
3. Is it linear? If so solve by integrating factor.
4. Is it separable? If so separate and integrate.
5. Write it as M(x,y)dx + N(x,y)dy = 0. Is it exact? Homogeneous (y = ux substitution)? Is there an integrating factor function of x or function of y?
6. Is it some special equation like a Bernoulli nonlinear equation?
Now if it is second order then:
7. Is it constant coefficient? f so use the characteristic equation and ##y_h,\, y_p## if it is non-homogeneous.
8. Is the ##y'## term missing? If so let ##u=y'## making a first order equation in ##y'##.
9. Do you know one solution so you can reduce the order?
10. Is it linear, maybe solvable by series?
That should get you started. You usually won't have to go all the way down the list.
47K
