Another Question About Angular Momentum in QM
Bobbo Snap
Show that the Hamiltonian H = (p^2/2m)+V commutes with all three components of L, provided that V depends only on r.
In previous parts of the problem, I've worked out the following relations:
[L_z,x] = i\hbar y, \quad [L_z,y] = -i\hbar x, \quad [L_z, z] = 0,\\<br /> [L_z, p_x] = i\hbar p_y, \quad [L_z, p_y] = -i\hbar p_x, \quad [L_z, p_z] = 0,\\<br /> [L_z, L_x] = i \hbar L_y, \quad [L_z, r^2] = xy(xp_x - yp_y), \quad [L_z, p^2] = (xp_x -yp_y)p_xp_y
where
p_i = \frac{\hbar}{i}\frac{\partial}{\partial i}, \quad r^2 = x^2 + y^2 + z^2,\\<br /> p^2 = p_x^2 + p_y^2 + p_z^2, \quad L_z = yp_z - zp_y
I started with [L_z, H], expanded it, canceled a bunch of stuff and wound up with,
[L_z, H] = \frac{1}{2m}(xp_yp_x^2 - yp_xp_y^2) + xp_yV - yp_xV + Vxp_y - Vyp_X.
Assuming I did everything right, I need this equation to equal 0 to show L_z commutes with H and the problem suggests that this can only be the case if V is a function of r, but I don't see how to get there. Any help would be appreciated.
Ok, so I can simplify that last equation to get
[L_z, H] = \frac{1}{2m}[L_z, p^2] + [L_z, V] =\frac{i\hbar}{2m}(p_y^2 -p_x^2) + [L_z, V]
How does this imply V must be a function of r?
(I guess I should have seen this from the form of the Hamiltonian).
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
It's given a gas of particles all identical which has T fixed and spin S. Let's ##g(\epsilon)## the density of orbital states and ##g(\epsilon) = g_0## for ##\forall \epsilon \in [\epsilon_0, \epsilon_1]##, zero otherwise. How to compute the number of accessible quantum states of one particle? This is my attempt, and I suspect that is not good. Let S=0 and then bosons in a system. Simply, if we have the density of orbitals we have to integrate ##g(\epsilon)## and we have...
