Help with an Electromagnetic tether robot
The discussion centers on building an electromagnetic tether robot that maintains a variable distance from an electromagnetic beacon, ranging from 20 cm to over 10 m. The project requires a transmitter emitting electromagnetic waves at a specific frequency, with a receiver using an LC circuit tuned to that frequency. Participants suggest using inductive sensors and a micro-controller for distance measurement and to implement commands for moving closer or farther. The decay of the magnetic field at a rate of 1/r^3 is noted as a consideration for distance calculations, alongside the need for serial communication for command signals. Resources like frequency-shift keying and voltage-to-frequency converters are recommended for effective data transmission.
atbaum
As a part of a school project I am required to build an electromagnetic tether robot. The robot needs to stay a constant distance from an electromagnetic beacon. As well as keeping a constant distance the transmitter can change the desired distance. (eg. move closer/move farther commands). The robot must be able to come as close as 20cm and as far as about 10m or more.
After hours of research and internet searching I'm at a loss on how to implement the magnetic transmitter/receiver.
I'm thinking the transmitter will give off electromagnetic waves at some frequency and then the receiver will have some sort of LC circuit that has the same resonant frequency as the transmitted signal. Our project description says that the robot should read the signal using a couple of inductive sensors and then use a micro-controller to determine the distance.
What I am unsure of is how exactly I can make this transmitter/receiver and how I can get a distance measurement on the receiving end as well as the move closer and farther commands. I was thinking I can use the fact that magnetic field decays at a rate of 1/r^3 but there also needs to be some sort of serial communication in order to command the robot to move farther away or closer.
Any tips or resources to help me with this would be awesome.
You might consider using the industry standard ADVFC32 voltage-to-frequency or frequency-to-voltage converter to send your data unidirectionally.
See pages 5 and 6 for a high noise immunity data link. Instead of using the optocoupler as shown, substitute a IRED transmitter and a photodiode receiver on your movable object.
http://html.alldatasheet.com/html-pdf/48916/AD/ADVFC32/125/5/ADVFC32.html
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
