Inverse kinematics of manipulators
To learn about calculating and simulating inverse kinematics of manipulators in Matlab, several resources are recommended. One notable book is "Robotics: Basic Analysis and Design" by William A. Wolovich, which is praised for its simplicity and practical examples. Additionally, a specific forum link related to programming a robotic arm is shared as a useful resource. Beginners are encouraged to explore these materials for foundational knowledge in the subject. Overall, these recommendations aim to assist those starting in the field of robotics and inverse kinematics.
asteorit
Hello,
I would like to learn how to calculate and simulate in Matlab inverse kinematics of manipulators.Can you please advise me some good websites or books. I am a beginner.
Thanks for any advice.
I really advise anyone knows a book or website solution for the inverse kinematics of a manipulator?
Hello asteorit,
I had once the same questions as you.
And the book that was good for me was:
Robotics: basic analysis and design
William A. Wolovich
This is an old and simple book with good examples.
I used this book to program my arm robot:
http://www.lynxmotion.net/viewtopic.php?f=6&t=4452
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
