Discrete Fourier Transform question
The discussion centers on a question about performing a discrete Fourier transform (DFT) by hand, specifically for the input {1, 0} transforming to 1/2{1, 1} as presented in R. Bracewell's book. The responder suggests reviewing the definition of DFT and the normalization factors, noting that the provided transformation is typically associated with the inverse DFT. They emphasize that computing a DFT is similar to finding coefficients of a Fourier series, with normalization being the main difference. For clarity, they recommend revisiting the basics of Fourier series to aid understanding. This exchange highlights the importance of grasping normalization in Fourier transformations.
kakolukia786
Hi, I am learning Fourier transformation by my own. I am reading a book "Fourier Transformation" by R. Bracewell. In chapter 11, in examples of discrete Fourier transforms, it gives for N =2, {1 0} transforms to 1/2{1 1}. I can do this in MATLAB but I can't figure it out how to do it by hand. Searching over the internet, I came across some material but it did not help. Can someone explain me how to get those transforms. Thanks
Bracewell's is an excellent book. The result you quote should be obvious except, perhaps, for the normalization in front which would usually be used for the inverse DFT (the forward DFT would have the factor 1). I don't have this book here but look at his definition of the DFT and check the normalization.
Computing a discrete Fourier transform is basically the same as computing the coefficients of a Fourier series (except for the normalization factor). If you are confused by this simple question, then reviewing how to compute Fourier series might help.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
