How Do B and Gamma Values Affect Polarization in Electromagnetic Waves?
Rubiss
I'm currently trying to understand linear and circular polarization of electromagnetic plane waves. Let's say I have an electric field given by
\vec{E}=Acos(kx-\omega t)\hat{x}+Bcos(kx-\omega t - \gamma)\hat{y}
A is given and nonzero. I want to find what values of B and gamma that can make the wave linear or circularly polarized.
I can also write the electric field as
\vec{E}=Re \big((A\hat{x}+Be^{-i\gamma}\hat{y})e^{i(kx-\omega t)}\big)
For the linear polarization, I'm thinking I can either make B=0, or gamma equal to n*pi if B is not equal to zero. Can anyone comment on my thinking?
For circular polarization, I'm thinking I need to have A=B and gamma equal to n*pi/2 for odd n. I will have right handed circular polarization if n=3,7,11,... and have left handed circular polarization if n=1,5,9,... Is this thinking correct?
Is there an easier way to do this that I am not seeing?
Are you sure it's not cos(kz - wt) etc.? Because if not this is not a possible e-m wave.
Assuming propagation in the z direction, you can solve this by writing the E field at z = 0, writing the x and y components of E and eliminating t between them. The result is y(x,phi,A,B) which then makes it obvious the restrictions on B and phi you must impose to effect linear or circular polarization. You could even go further and do the same for elliptical polarization for extra credit ...
OK. I never did respond to you directly. Here goes:
Right.
Almost right. B can be + or -A. The choice of sign determines right or left circular polarization. That makes it tantamount to choosing n for γ the way you did.
Hard to say since you didn't tell us how you got your results in the first place ...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
