Power Supply Question: Can It Handle 6A @ 35V?
A power supply rated for 4 amps at 35 volts cannot effectively power a device that requires 6 amps at the same voltage, as it would create a voltage divider situation, resulting in insufficient voltage for the device to function properly. Using a 3.05 ohm resistor to limit current would lead to a voltage drop, providing only 22.8 volts to the device, making it unlikely to operate correctly. Additionally, the resistor would dissipate significant power, potentially requiring a heatsink and fan due to the 48.8 watts of heat generated. For stable operation, a more powerful power supply is necessary. In amplifier configurations, bridging two amplifiers can effectively double the power delivered to a lower resistance load, but the amplifiers must be capable of supplying sufficient current to avoid clipping.
Tesladude
Ok this may be a stupid question but what the heck.
If I have a power supply giving max of 4amps with 35v
and what I am powering draws 6 amps at 35v,
then that means the device has 5.7 ohms of resistance.
If I put a 3.05 ohm resistor (ish) then this will drop the amps down to 4, but will it still power the device... functionally?
The resistor and your device will form a voltage devider. You'll get 5.7/(5.7+3.05) * 35 = 22.8 V across your device so it is not likely to work.
The power dissipated in the resistor is I^2 R = 4*4 * 3.05 = 48.8 W which will be a problem as well.
Your resistor might require a heatsink and a fan.
if the device needs 6A to operate then its not likely to work with only 4 amps or if it does it will be unstable in operation
Adding a resistor is only going to make the situation worse
you need a beefier PSU
Dave
ok thanks, I forgot about the voltage divider so It seemed possible for a moment, this isn't a project I'm working on, I was just day dreaming.
BUT
Sense I have this thread open, and davenn is here:
I read that bridge mode in amplifiers will, for example, take a 100 watt amplifier at 8ohms and turn it to a 200 watt amplifier at 4ohms.
I was going to use 4 tda2050 amps, each running one speaker, but if I use 2 amps in bridge running 2 8ohm speakers in parallel, would this give me double power into both speakers? So as if each speaker had it's own amplifier twice as strong?
As long as you realize that you don't get anything for nothing then you can't go too far wrong. Connected in a bridge, two amplifiers will (if they can) deliver twice the current into a load than they would, individually. They are each 'seeing' a load of half the resistance of the original load. If the amplifier can't deliver enough current then you won't get that power - it will clip.
ok thank you! I must say you explained that very well, someone else I asked wasn't being too clear haha.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
