How Can Insulation Thickness Prevent Condensation in a Thermocouple System?
Insulation is crucial for maintaining the temperature of flue gas in a thermocouple system to prevent condensation. To avoid gas temperatures dropping below 100°C, insulation thickness must be calculated using Fourier's Law of Heat Conduction, considering thermal conductivity and temperature differences. Reducing the cooling water flow rate or increasing its temperature can also help maintain higher gas temperatures. However, the most effective solution involves applying insulation directly between the gas pipe and cooling water. Accurate calculations based on heat transfer principles will determine the necessary insulation thickness to prevent condensation effectively.
Muhammad Awais
Dear Seniors and Friends
We have a thermocouple consisting of two pipes . In the inner pipe there is the flue gas and the outer pipe we have a cooling water . Currently we are facing a problem that gases are being condensed below 100 C because of cooling water .We have to apply insulation between the inner pipe and the cooling water so that gas outlet temperature is limited to 100 C.
What approach can be used of insulation thickness so that condensation can be avoided .
Flue gas enters at 1500 C and should leave at above 100 C to avoid condensation.
Cooling water enter at 20 C .
Thabking you in anticipation
Muhammad Awais
Am I correct in saying that you have some sort of double-pipe heat exchanger? In any case, there a probably a few things you can do to avoid condensation of the gas, although I am not sure if your test-conditions will permit some of the suggestions.
1. You can reduce the flow rate of the cooling water. This will increase the thermal resistance, maintaining a higher gas temp.
2. If you can increase the temp of the cooling water. This will reduce the heat transfer rate.
3. As you suggest, you can insulate the wall between the 2 fluids. Something like an air layer or inert gas would be good as they have low thermal conductivities.
4. A thicker wall (possibly a composite wall, containing multiple layers of different materials with low thermal conductivities)
Thats about all I can think of at the moment, good luck with it.
Thakyou Sanka to give me a quick response ...First two point that u told me is really helpful for me and 3rd point is impossible for use air or inert gas in my case. I have to apply insulation between gas pipe and coolig water. Can you help me which approach i have used to get insulation thickness.
Thanks
Muhammad Awais
To get an estimation for the thickness you require, you can use Fouriers Law of Heat Conduction which is;
\dot{Q}=kA\frac{dT}{dx}
where dx is the thickness of the medium through which the heat travels (i.e. the insulation thickness). For a given material you will obtain some k value (thermal conductivity), you know the area. You need to assume a temperature difference (dT): in your first post you said the gas cannot go below 100°C and cooling water is 20°C, thus, you dT should be based on this. Remember it is the temp of the hot fluid AT THE WALL - the temp of the cold fluid AT THE WALL.
Also, you will need to know Q to solve the equation, you can get this from an energy rate equation:
Q=\dot{m}CpΔT
This leaves one unknown in the equation and by manipulating the conduction equation, you can solve for the thickness, dx.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
