Detection of inter-turn winding-short fault in 1-phase transformer
A simulation and experimental study of inter-turn winding short-circuit faults in a single-phase transformer revealed that the fundamental component of the no-load current increases under fault conditions, while harmonics remain stable. This results in a decrease in Total Harmonic Distortion (THD) of the no-load current as the fault severity increases. The discussion suggests that leakage reactance at harmonic frequencies may contribute to this phenomenon, as harmonic currents encounter greater reactance compared to the fundamental current. Additionally, the properties of the iron core at higher frequencies, particularly its complex permeability, may play a role in this behavior. Overall, the findings prompt further investigation into the relationship between fault levels and harmonic behavior in transformers.
Shantanav
Hi all,
I have simulated (both in software and experimentally) inter-turn winding short-circuit fault in a single-phase transformer (working as a stand alone unit). I have the following observation but don't know the reason behind it:-
The fundamental component in the no-load current is increasing under fault, but all other harmonics (3rd, 5th. 7th etc) remain almost unchanged. So, under fault the Total Harmonic Distortion (THD) of the no-load current is improving i.e. decreasing.
Higher is the level of fault (i.e. number of turns shorted), lower is the no-load current THD.
Any ideas, why this trend is happening ?
Cheers,
Shanto
My guess:
Leakage reactance at nth harmonic is nX its line frequency number of ohms. So harmonic currents see more ohms of series reactance than does fundamental current.
What are properties of the iron core at harmonic frequencies?
Try some searches on "complex permeability".
Above some frequency well into audio range the iron no longer has any effective permeability .
http://www.diva-portal.org/smash/get/diva2:125733/FULLTEXT01.pdf
So as frequency goes up, leakage reactance becomes increasingly larger proportion of total because the core acts less and less like textbook iron..
That can't be the whole answer, but hopefully is food for thought.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
