Equilibrium, Charge Balance, Mass Balance
The discussion focuses on writing the charge balance for a solution containing various ions, emphasizing the need for electrical neutrality where the sum of positive charges equals the sum of negative charges. Participants clarify that while a balanced chemical reaction equation can assist in mass balance, it is not necessary for establishing charge balance. The importance of separating positive and negative charges to achieve balance is highlighted. Understanding these concepts is crucial for solving related homework problems effectively. Mastery of charge and mass balance is essential for analyzing chemical solutions.
whatlifeforme
Write the charge balance for a solution containing H(+), OH(-), Ca^(2+). HCO3(-). CO3^(2-) , Ca(HCO3)+, Ca(OH)+, K+, and CIO4(-).
Also, I am having a trouble understanding the concepts of mass balance and charge balance.
The only thing I know to do is put the positive charges on one side and the negatives on the other, and then change the coefficients.
you need a balanced chemical reaction equation
Do it then.
Charge balance means just that the solution is electrically neutral - sum of all negative charges equals sum of all positive charges.
No. Reaction equation can help in writing mass balance, but even that is not required.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
